Mk2 Pic Request Please
Hey guys...
I'm having a problem with my bonnet... it pulls alright but doesnt 'pop' up so i have to pull the handle and run round before the handle goes back to open it....
I cant remember if there is something missing of if i just haven't put the cable in tight enough so would like a pic of one that does 'pop' so i can compare to mine... the bit i need is where the spring is on the actual bonnet
Thanks in advance!!
:-D
Edited by KatPoloMK2
  • Replies 12
  • Views 1.6k
Just make the cable tighter in the bay. Should sort your problem
There should be a spring on the underside of the bonnet that pops it up and stops the catch from relatching.
It's quite common for the spring to rust and snap off.
Spring is there but it doesnt pop up... my dad thought there was a rubber bump stop thing that sat on the end of the spring??
Hence why I want a pic :)
mine was doing the same, i just got a new spring and it was fine.
spring must be weak , no rubber buffer on them
mine pops up so i can open it , but it doesnt sit proud off the wings
Also,the spring rests on a plastic tab. If this is missing,there's a vital couple of mm's.
Could just need the latch adjusting down a touch? Does it sit perfect with the wings or slightly proud?
Id carefully stretch the spring a little,could be that being compressed for a quarter of a century has had an adverse effect on its length. I cant measure mine (or take a photo) at the moment though.
So shown here very poorly,as its the only pic i have to hand where its in a picture,the plastic tab that protects the paint..
One of the car in question,too? Oh go on then..
Yes thats the little beast lol
I got the plastic bit that sits on the slam panel so thats alright... the spring is one that i got second hand coz mine had rusted!
I will try n have a look at the cable the weekend and see if i can tighten it anymore...
Thanks for the help so far!
need anymore help give me a shout, i'm only in bitterne
Cheers dude.... even a look at yours would be enough for me to figure out what the problem is!
yeah just pm me and pop over any evening this week
What engine have you got in your polo?
The engine in mine is a 6n2 GTi unit with ally block,but that's not what you're on about (as of my Avatar).
That in the picture was a 1.4 8v ABD Golf engine,but i was stripping that red S when i took the photo. It was full of scrap metal so literally a skip! You can see the shadow of the engine bay of the blue S bodyshell next to it,as i was re-shelling the car at the time. Through the windscreen,you can see there's no dash etc - you can actually just make out junk in there and the mechanism for the passengers mirror adjuster..
My gallery thread will explain further,though it needs updating,bit of a hijack going on so i'll nip it in the bud.
