MOT Fail
:( well my 6n just failed it's MOT. I was expecting it to, but now I need to try and source a couple of bits so I can get it all ready to pass :)
First off, this is my list of failures:
  • Offside Headlamp aim too high [1.8]
  • Nearside Headlamp aim too low [1.8]
  • Offside Steering rack gaiter split [2.2.D.2d]
  • Offside Front constant velocity joing gaiter split [2.5.C.1a]
  • Parking brake lever has no reserve travel [3.1.6b]
  • Exhaust emissions carbon monoxide content after 2nd fast idle excessive [7.3.C.2b]
  • Exhaust emissions Lambda reading after 2nd fast idle outside specified limits [7.3.D.2b]
1. I need a new Cat Converter, does anyone know which of these is the right one for my 97 1.4 8v 6n (engine code ???):
http://cgi.ebay.co.uk/VOLKSWAGEN-POLO-1-4-...=item35af27f58d
http://cgi.ebay.co.uk/VW-POLO-1-4-07-95-01...=item20ae9d70dc
http://cgi.ebay.co.uk/VW-POLO-1-4-8v-07-95...=item1e5e7d5ba1
http://cgi.ebay.co.uk/VW-LUPO-POLO-1-0-1-3...=item20abad98be
2. Can anyone point me in the right direction to be able to get the steering/cv boot gaiters from a reputable company?
3. The parking brake - would that just be an adjustment on the cables? or would the cable need replacing?
I know the headlight alignment isn't hard to do, just need to use something flat :lol:
Any help is greatly appreciated. I am not going to dump my beautiful little black beast, it's too good to lose :)
  • Views 3.4k
gsf will have your cv and steering rack boots on the shelf the hand brake looks like adjustment is reqiured
with the emmisions post up waht the readings were and someone will poss be able to help some more
Quick post then since I need to catch a train soon.
Fast Idle Test:
Engine speed: 2500-3000rpm - MANUAL CHECK - PASS
CO: <= 0.300% - 0.664% - FAIL
HC: <=200 ppm - 155ppm - PASS
lambda: 0.970-1.030 - 1.062 - FAIL
Second Fast Idle Test:
CO: <= 0.300% - 0.646% - FAIL
HC: <=200 ppm - 138ppm - PASS
lambda: 0.970-1.030 - 1.057 - FAIL
Natural Idle Test:
Engine Speed: 450-1500rpm - MANUAL CHECK - PASS
CO: <=0.500% - 0.457% - PASS
Also, would a no.99 relay for wipers fit into my 6n?
Cheers :)
Technically headlamp alignment can only be done properly with a alignment unit like the one in the MOT station but a lot of people recently have come to me after being failed for it.
Are MOT testers actually getting too stupid to use screwdrivers these days but then it may explain the amount of poorly aimed headlights on cars these days.
The emissions failed at the 2500rpm test advise there would be to bung in some thoughté Advanced Formula Gas Treatment and go for a spirited run the night before and right before the test.
The fail points are not ridiculously over so it might just need a good clear out, give it some new plugs and leads as well if its not been done already and the timing checked after all there's no point forking out on a new cat if its not needed.
I thought 6n's had relay 99 as standard, but if not then yes its a direct swap for relay 19, one of the most useful mods going.
Edited by Cymro
Youve missed the point ALOT there mate. I'm not sure on spesfics but the testers is allowed to adjust/fiddle with either one or two things on the test, one is headlights. SO maybe other things had been done and they arnt allowed to do anything else. I work in a garage and get alot of mot assists and quite common for them to adjust the alingment.
The fail avoidance guide for emissions:
1 - Buy some redex
2 - Put redex into fuel tank (just bang the whole fucking lot in there)
3 - fill up with some premium fuel (vpower etc)
4 - Go for an "adventurous" drive just before the test
5 - Bobs your uncle, passed emissions.
:D
Try posting in the technical section.
