Front hub nut size 2004 vw polo
Hello everyone trying to drop the box and change the clutch on a 2004 vw polo but not got the correct size socket for the front hub nut it looks like a bi hex 36mm can anyone confirm this
  • Views 5.3k
Yep you will need one with flat face, and replace the nuts one use only. thought i put thread lock on and re-used them last time.
