Pile off 90 -94 polo bits with pics
Clearing my garage so got some bits for sale.
Brand new bits:
MK3 polo new sump (Hadrians Panels) £30 posted
2x new in the VW bag bleed nipples £3.20 posted
G40 boost hose (one the goes next to the window washer bottle joining the 2 plastic pipes) £22 posted (cost £24+ VAT)
Colour coded factory primed Boot plinth for mk2 golf all marked up ready for filing out the holes to fit a mk3 polo cost £30 open to offers
Fuel rail retaining bolts £1
Rear engine mount bolt (long one that goes through the rubber) £1
Gear Shift finger clamp retaining bolt 50p
Genuine new storage box for Radio apature £12posted
2nd hand bits
Fan cover and mounting bolts £4
G40 fan cover with “Ladelhuft gechult” (Intercooler) sticker and mounting bolts £4
Drivers seatbelt £5
Passengers seatbelt £5
Rear seat belts £5 each
Cabin Heater flow and return pipe and bulkhead grommet £3
Cabin Heater (no squeek) £25 posted
"Genesis” rear badge £1
Squareback cream headliner ( factory sunroof version) £8 (will need laid out in the sun for about an hour or taken in the house and laid out to get it nice soft again and take the wrinkles out).
GT/G40 front and rear VW badges for Grill and boot (with backing panel) VGC £15 posted
GT/G40 sunroof winder and backing panel £3
G40 plastic boost pipes (pair)£18
standard boot carpet VGC £15
Cat to mid pipe genuine VW exhaust clamp only a year old £3 posted.
MK4 polo (mk2 golf) electric window switches and 1ft of cable
Wheel spacers 3mm (pair)
Fuel lines - flow and return £10 posted
MK2/MK3 Saloon Right rear light bulb holder £5 posted
Shift finger for gear linkage with Cage and clamp £10posted
Brand new genuine bolt for above 50p extra
induction kit i made for a Spi AAU/AAV engine using GT air intake £10posted
GT speedo (94K) needs a new speedo needle but its a 2 sec job £5
Radiator £15 (£10 postage in genuine VW radiator box)
Boot plinth VGC standard black £10posted
Intank fuel lift pump £13 posted
Rear boot strut cover caps £1 each
Passengers roof mounted grab handle as fitted to CL, GT, G40s £1.50
Speedo cable
Brake light switch £1
Headlight switch £1
Rear screen switch £1
Complete sunroof in black £15 (postage on sunroofs is £12)
Complete sunroof in calypso green £15
oil breather set up used for aau/aav engines with breather pipe to rocker cover £5
1960s brass body tyre pump £18 posted
1960s AA badge £12 posted
Anti roll bar rubbers almost new fitted but the cars been off the road for 3 years £6posted
G40 brakes ideal for upgrading other mk1-3 polos
What you get:
2x Brax Calipers (GSF) they are 6 years old, but only used for 4, were overhauled last year when they went on my GT saloon with new seals, sliders, rubbers calliper to pad carrier mounting bolts ( all genuine VW bits) with bleed nipples.
2x G40 pad carriers
4x Dephi pads as new lucky if they have done 1000miles
2x Delphi Disks as new lucky if they have done 1000miles
4x pad carrier to Strut bolts (1 year old)
3 of the 4 anti rattle clips
All fullying working/free and in VGC (callipers painted front new in Black hammerite smooth and pad carrier done to match).
£85 posted
Also G40/GT Bare rear axle £45 willing to post if you send a courior.
Complete VW rear drum brakes
Bought all of the below brand new from GSF/Autoparts when I did up my saloon last year as a GT, used for only 6 months.
2x Drums
2x wheel bearings
2 wheel cylinders and mounting bolts
Set of shoes
Fitting kit all springs tabs etc
2 handbrake cables
£65 posted all carefully wrapped up in sealed bags
Can also include:
Pair of Brake back plates£4
Pair of stub axles & 8x mounting bolts £16
+ other stuff in the photos I have probably forgot about.
No photos but for sale:
90 – 94 Saloon rear wiring loom £40posted (Ideal for GT/G40 conversions as all the fuel injection wiring to the tank and inline pump are built in).
90 - 94 polo coupe/squareback rear interior wiring loom ( passengers feet to boot including intank and inline fuel pumps GT/G40 connector) £25 posted
Standard boot carpet manky but ok £1
Squareback rear boot side carpets minty condition (both early (velcro and plastic plug) and late (all plastic plug) versions available) £15 posted each pair.
Paypal accepted, able to post all of it and can be collected.
discount on multiple items of value over £10.
all funds go to my squareback lol.
heres some pics:
Edited by genesisGT
  • Replies 31
  • Views 1.4k
G40 top half off air intake panel behing headlight £5 is that posted?
Hi Pete, yeah. But genesis Chris has his name on it as he pmed first. If he changes his mind will pm you.
I will take the door locks, pm me details
sam.
do you have a front tow blank thing that slots into the front bumper?
dont think i read it or can see it
cheers
01mlacey - dont have one of them sorry
Spanerman - pm on its way
Edit: all items paid for posted.
I'll take the AH coded Key.
Also, do you have the little interior trim which fits over the interior mirror handle.. not the rubber boot, the actual knob?
Thanks!
Can i have the black boot plinth and are all the clips there? PM me.. Thanks
Edited by jackjamesw910i
EnthusiastOwned™ pmed you mate.
jackjamesw910i - hi mate confused me - the boot plynth is held on with 4 bolts there are no clips/bolts with it. the boot panel cover for the tail gate also pictured is held on with clips but none are included as per the photo. cheers. :-)
in the second pic down there is a cold air feed pipe? that goes behind the grille to the intake on the airbox, looks to be for a polo cl kind of thing, how much posted? i mean the thing thats in the top right corner of the pic?
That's my home made (using all genuine vw bits) cold air feed as the standard design takes hot air from the engine bay. Just makes it like a GT straight from the grill. Can do it posted for £8.50
Sorry about the description fail GenesisGT, I meant the tailgate cover. The only reason i asked about the clips is I'm missing like 3 but it still holds fine so all is well. Can i have your email so i can paypal you the money. Thanks alot
all items paid for will be posted today.
How much for the black coupe headliner and sunvisers together posted?
£23 posted
£8.00 posted? ;)
Hi, will take the ignition coil. If you can pm me your paypal again I will send the funds over.
Grant
list updated, pms replied to.
open to offers on all bits left.
Didn't see a price for the little VW badge above the Polo badge in this pic -
How much for it posted? Would take it if it's the one the same as the one on the left side of the saloon boot?
PM'd you about seat belts.
£15 posted for the 2 seatbelts
Alex, yeah its a saloon one can post it for £2
Cool, can you PM me your paypal address and I'll get it over to you in an hour or so dude?
all parts paid for posted.
list updated.
I need GT/G40 black sunroof winder now :)
Yeah can do the handle and backing plate for £4 posted
