Water leak in passengers footwell
So got in my car this morning to go to work, happened to glance in passengers footwell and noticed a puddle, thought "oh it must of come off the gf's shoes last night"
Then I saw a few drips land in the puddle...so I leant forward, pulled down the foam below the passengers airbag and was greeted by a rush of water :| Literally was around half a sink full >.<
Luckily I have vw rubber mats so i managed to balance the water and pour it out of the car :/ It has been raining alot but also washed my car yesterday, so could be from that?
Only managed to try and see where it has been coming from after work
Has dried out a bit...my heater resistor and the plugs were soaked :/
As you can see, there is water in the socket for the resistor and on the wires
Now my friend has told me it might be the plastic panel at the bottom of the windscreen...I opened the bonnet and have found a crack that must be dripping into the pollen filter beneath..i've tried researching but found little, apart from one person said that it might have got in through the pollen filter seal?
Can anybody suggest where this might have come from?
Picture of the crack:
Also a Picture of a hole under the seal...take it it's meant to have a screw in..not sure where the water would go though?
Don't really want to try pouring water over it to find where it's coming from either, as don't want any more water in the car..however might have to :thumbsdown:
Any help will be greatly appreciated..
Also if there is another thread on this..sorry.. I did search but couldn't find anything
  • Views 3.3k
Righht, I think I might know what the problem is now.
After searching around inside the dash for any leaks (none) I decided to conclude that the seal on the pollen filter was the problem. ( thank you interwebs. )
So looking at the heater system in the dash more carefully and could see that the pollen filter was directly above the fan/blower motor...
(Some History)Now, a year ago, the old fan seized up and the resistor was pretty much burnt out...thought nothing of it and replaced them both, no problem.
So what i've concluded has happened, is water has poured down into my fan, then across and down into the resistor and poured out the other end and into the passenger footwell. Explains why my old fan went, why the wires were burnt out and also why my resistor today seemed as though it had been submerged in water.
Spoke to the old owner today and he said that he had fixed the crack previously which can be seen, but obviously water had got into the old fan etc.
Bodge fix until tomorrow:
180810_10150393241095430_763145429_17532
180819_10150393243095430_763145429_17532
Washproof plasters ftw ;)
Anyway, yeah, this thread can probably be closed. lol
wouldn't some black silicon sealant have been better than that bodge lol
Edited by shakennstirred
