Advice needed
Right seeing as though I'm a total noob when it comes to paint i need some advice.
The only thing I've ever repainted was a boat lol
I'm getting this painted on my bonnet in a few weeks but first i need to re-paint a spare bonnet matt black so that the design can be painted on.
I need to strip, prime and paint my spare bonnet. I need to get almost perfect finish so that it doesnt look crap once the design has been painted on.
Can nitromors be used to strip the old paint off, or is it a case of wet/dry sandpaper and loads of elbow grease?
Also when I've finished painting whats the best way to clean the paint ready for the design to be sprayed on?
Is there anything i should be looking out for?
you dont nead to strip all the paint of just ruff it up a bit with light sand paper so the new paint can stick..
and paint away..
As above you don't need to strip the bonnet, just key up te surface for the paint to stick to. However sandpaper is not the best idea, you'd be best using very fine scotch bright. Using sandpaper increases the risk of you using to higher grade and damaging the surface. However if there is any rust or damage to the bonnet, insure it is fully ground out primered and flat back using a black guide coat to get the flattest possible finish.
Sorry to hijack but what do you suggest for de-greasing/cleaning the surface before paint?
get down machine mart and buy the 27 quid random orbital sander, will give you a nice flat finish ready for your paint and it's cheap cheap cheap
Use surface degreaser before paint ^^ lots of people make it.. 3M etc
would personally use paper and a block as opposed toa machine sander to get a straight finish, block it down to 600 then shoot your primer and paint, job done :)
panel wipe from a paint supplier on the degreasing situation
