Hello
Just bought a Mk iv in red with a genuine 40,000 miles(still had original tyres on) for £600. Really happy with it and it drives very well. Just one thing that concerns me. The temperature gauge doesn't go above 70 degrees and most of the time while driving it just sits at the far left position. Is this normal for a polo. All other cars I have had seem to sit around the 90 degrees mark. Any help would be much appreciated. thanks Phil
  • Replies 8
mines does exactly the same
Might be the Hud not an engine problem heard this can happen with mk5's not 100% tho :/
does it stay at 70 all the time,like while your sat in traffic?
mine does the same, its perfectly normal
when u stop for like 30 seconds, it should go up to about half way, if it does then nothings wrong :)
Sounds like the thermostat is stuck open, and the coolants being constantly cooled. Best way to check is to let the car warm up to 90 and then drive it around for abit, and if the temp comes back down to 70 then its a dodgy thermostat!
mine does not move until i hit traffic but goes hafway when i do but heater is hot
Thanks guys, It moves up slightly in traffic but never any where near half way, as soon as it gets a run it goes back down again. heater blows hot.
a dodgy thermostat same thg happened to mine so dont worry about it as above says if in traffic it goes to halfway then back down after driving away you have no probs
