too low for mot
got refused an mot today, they said my car was too low to get on the flat ramps :(
anyone else had this? I'm down 120mm on 13"s on my 6n, and they said they wouldnt just put wood under the wheels to get it on!
going to raise it up a tad, bit of a ballache :(
Edited by samfenna
  • Replies 51
  • Views 7.3k
well id thay thats a tad low. but as far as I'm aware theres no such thing as too low. may get advisory at most.i no u never said they didnt test it but still. find another test center?
yeah I've booked it in elsewhere :) hopefully itll fit on these ramps!
just raise it like you said
then drop it afterwards :badgrin:
i used to lift mine up for mot
I had an advisory on my old 6n "vehicle has been excessively lowered" i wasnt refused a mot test and it passed.
Had this happen a few times, its not so much the ramps but the jack that slides along the ramps under the car, if your cars too low the jack won't fit under it. The last place used some wood to lever the car up, he then started moaning about how i must be one of the twats that hold him up at speed jumps lol. It wouldn't be so bad but it had lifted the coilies as much as I could so I didn't have any hassles with it being too low :lol:
yeah thats the problem, its the sliding jacks!
Some places will put the effort in and at least try but I've had others that just looked at it and said no chance
Just thought i would say i have never had any problem's with my car and it is very low not too sure how far but on my summer wheels (13's with 50 profile's) the exhaust is just off the floor by about a 1 inch! but then again i do the mot's! hahaha :D
Yeah mine was refused an MOT last year because he couldnt get the slide jack under it. and when he took it off the ramp and back over the brake test rollers he slammed it onto the cross member thats just behind the TCA mounts, I cringed! He said come back when you have some proper suspension on :D I promptly took it some where else where they had no problems!!
Well funny..
Even i had to push up against the front bumper so he could get the lift bar past the chassis brace,and I'm only down about 60mm at the front. I know the car in question is a 6n and they're not so bad,but it does make me wonder how heavily lowered pre-94's get on.
you see this all the time tbh, personally I've never encountered it but my best mate is an MOTer and since he does all the work on my car he goes above and beyond to get the MOT sorted =D
my only concern with yours is that 120mm down on 13s, surely youve removed the helper springs on the coilovers which could well be an MOT failure anyway
nah mate, helpers arre still in, I've got about 4cm between my subframe and tarmac, on 50 profiles on 13''s :)
They'll refuse to do it coz they can't be bothered! I went to get my tracking sorted and the bloke walked out, saw my car and turned back saying its way too slammed, however Supertracker seemed to have no problems whatsoever.
Lowered cars are perfectly acceptable aslong as there is no rubbing from the tyres when on full lock.
I chucked 2 planks and always carry chunks of wood in mine just in case, and it passed it's MOT on saturday straight through no problems. Just raise it and wind it down when you get home! Sorted :)
Edited by petrolpiers1
Well not quite sure how to tell you this mate but if your helpers are still in your only about 75mm down, must try harder.
Yea man had the same problem last year!! An u had higher mine I no way mean
A rite ballache!!!
I've got mine this Saturday eeeekkkk but my cousin is doing it for me an an he said it's fine being that low so winner :D
A rite ballache!!!
75mm?
hardly
you dont even know what suspension I'm on...
mate, I've got my 6n on starmags, looks exactly the same height as this :) look so sick on starmags!
Samfenna - Your car is too cool! :lol:
cheers guys, good to hear the compliments :)
a friend of mine owns a mot station but they use a pit with a jack in the middle but mot guy said if a car fowled the floor when going over the rollers wich are used for testing break force and a car can fale if the tyers are fowling the arch inner arch plastic or anything around it
had same prob, got part way through mot and couldnt get slide jack under, i was waiting in the reception and could see they weren't very busy so i raised the coilys in the car park and gave it them back :D
On my MOT they had to get someone to lift the car a bit to get the jack under :)
