too low for mot
I've found someone who has a pit and luckily has a low trolley jack it passed last year althought he ahd issues on the break rollers haha
  • Replies 51
  • Views 7.3k
mot aside..
getting a recovery truck to take you and your car home when needed can be tricky where slammage is concerned ... been there :lol: ,recovery driver laughed as drove away from my lowered polo :roll:
bare it in mind boys n gals ;);)
nah mate, helpers arre still in, I've got about 4cm between my subframe and tarmac, on 50 profiles on 13''s :)
Well not quite sure how to tell you this mate but if your helpers are still in your only about 75mm down, must try harder.
75mm?
hardly
you dont even know what suspension I'm on...
in all fairness... I can still see archgap...
this was my golfy on 195/45/13's :p :lol:
7528_1263054695536_1204774269_818247_378
Edited by Matt Mk3loon
aha you try tucking et-7 ;)
touché
75mm?
hardly
you have cheap coilovers that drop to -120mm and have helper springs... am i right or am i wrong?
and as i said in another post i fucked up with the maths, its more like up to 85mm you can drop without taking the helpers out (helper springs measure 35mm when compressed, take that away from 120 and you have 85).
feel free to look at my post in the other thread we were discussing it in to see the difference between coilies with helpers springs and coilies without ;)
mate just to give you an idea of how low 120mm is on 13" with small tires (and for a bit of shortage :lol: )
this isn't a mk4 polo, but it would give you some idea of how low some thing that is down 120mm on coilovers
there is no arch gap any way and that was with a bit of positive camber which is more apparent in this photo
it would have even more tuck on the front if the camber was set up right, but on yours you've got a good inch of arch gap. can you see where i'm coming from here?
Any way I'm getting away from myself here, your car isn't 120mm down because you still have the helper springs in and they stop you from being able to drop any where near the full amount, your not the first to make this mistake and you certainly won't be the last lol
Edited by McLOVIN
samfenna, was that pic taken at cheshire oaks? looks familiar
That is rad!
P.S. Sorry for off-topicness!
andymk4- yes mate, it was :) i work round the corner from there
Only reason a MOT station will refuse to test is through sheer laziness - I've had the same struggle with both MOT'ing and tracking.
Hyde road tyres were used for the latter and I put the polo in with a friend for the MOT.
I had to push the subframe up so the sliding jack could be moved, that was it. The brake rollers present a bit of an issue, but nothing a bit of care and attention can't solve.
UPDATE
car got its mot today :) it did get stuck in the rollers though, needed 2 people pushing to get it out :')
Just stupidness that low, all this scene following is a little much.
your 6n looks mad samfenna
it makes you laugh dunnit that they refuse those but would relish the attempt on say an lamborghini or similarly low hyper/super car
mine was on 15x7 with 165/50s and i hit the rollers but once we'd given it a bit of a lift he was fine and mine was the same down as far as i could go until constant scrub would happen but 2 people in the car was a push luckily the missus is only little lol
Edited by dub loon
75mm?
hardly
why do you care so much? :?:lol:
Guy is secretly a scene queen, thats why he cares!!
cos the chaps bragging about being super low, yet he aint doing it properly :lol:
Do you question why any one else cares when they reply to a post? :?
If you saw some one posting some thing that you knew wasn't true wouldn't you point out that it wasn't true?
Or should I just ignore it and leave some one to post inaccurate information on here that could mislead other users?
Edited by McLOVIN
He's definately no scene queen. Hes the scene bitch :unibrow:
i'll get my coat... :lol:
to bee honest mclovin, you seem abit up yourself :/ you haven't seen my car in person, or my arch gap, or my ride height, and yet your making out I'm doing some massive harm by saying my cars 12cm down? i know how low my car is, and i dont see why you should make a big deal because you disagree? before the car was lowered, i measured my arch gap with the alloys fitted, and 12cm brings the arch lip to exactly where it sits now. i dont see why its irritating you so much, it wasnt the point in this thread, and you haven't really contributed to it at all :/
Edited by samfenna
Right lets see if I can settle this argument.
A standard 6n 8v is 130mm high from the ground to the LOWEST point on the subframe. That is where the measurements before and after should be taken in my opinion.
Now your saying you car is 4cm...so 40mm from the subframe to the deck. I'll assume you've taken that measurement from the lowest point on the subframe.
So to me that would suggest you are 90mm (or 9cm if you prefer) down at the front of your car.
Which to me is perfectly acceptable.
There are very few people who actually achieve the suggested 120mm lowering on a 6n from the cheap coilovers. The lowest I ever had a 6n was 105mm down at the front, but it was silly to drive. That was a valver too so 10mm lower than an 8v to start with. So in theory if anyone with a valver says they are 120mm down they are either telling porkies or grinding their subframe away on the deck constantly.
you're not down 120. deal with it.
the photos you posted shows how big your arch gap is...
...assed?
not going to lose sleep
so I'm up myself for pointing out you ain't as low as you say you are? :lol:
The thing is it's not an opinion your trying to argue against, its fact. The fact is you can't lower a car 120mm on those coilies without removing the helpers, you said you haven't removed the helpers so you ain't 120mm down, I don't need to see your car to know that because you have already told me all I need to know.
And i'm pointing this out because what you are doing is giving out misinformation, if no one corrects you on this then any one that see it will then be assuming they have lowered their car 120mm when they haven't. Ok its not the end of the world thinking your lower than you are, but where does it stop? Should we just leave every bit of false information that gets posted on here? Or is it not our responsibility to point out false information when we see it?
From what I can tell the only contributions to this thread were tales of not being able to get cars on mot ramps, as I posted my experiences in this in this I guess i've contributed as much as any one else?
Sorry for pointing out the obvious, but who really gives a shit?
Edited by LOGiCALX
Everyone posting about it I guess? :?:lol:
