black trim thing?
hi got a mk3 bredy was wanting to know if i remove the plastic trim between font and rear side windows that it would be painted underneath or would i regret and be left with a head ache!!! cherrs
It is painted beneath, but be prepared to be faced with a bit of glue. Grab a fudge wheel drill attachment, and that should cure it.
Also, tip for next time, post in the correct section, you'll get a better response. There's a section for body work.
Warm it up with a hair dryer,that'll make it easier to peel off. And a little petrol on a cloth will easily remove any glue (though a fudge wheel is probably cheaper..).
boil the kettle and poor that over it then slowely peel it off, works a treat and leaves barely any glue behind
Don't be a pikey. Use a fudge wheel. They are only £5 and I'd be really surprised if you don't have a drill to use it on. If you use boiled kettle water it can damage the paint. Especially if its red it can make where the water hits go pink. Its also useful if you decide you want to take the door strips or something off.
everyone saying fudge wheel means toffee wheel :) you'll have a much easier job finding what you're looking for if you search toffee wheel instead haha :D
