paint coverage
right. I'm going to be painting my car in NATO green, will 750ml be enough? It says it will cover 9 square meters.
The car is a mk3 breadvan
Regards Sam.
  • Replies 13
  • Views 1.6k
brush , roller, spray gun or rattle can?
I'm thinking no its hardly enough...maybe with a carefull brush it might go
Foam roller/brush, ill just grab 2.5l from ebay then
Sam.
No way near! You'll need about 2.5l possibly more
depends how mad your going with it [inside panel edges, etc.]
where i work we order between 3 and 5L's for our repaint jobs.
As i will be rollering it on, i will just do the outside and leave the shuts ect
How many coats of thick military paint will i need? should i thin it down and do thinner coats or do one thicker one?
Sam.
If you thin it down you will gain more paint but if you thin it to much you run the risk of it not covering aswell.
But if you plan on giving it multiple coats it should be ok.
Well if i can get away with one coat i will....
So is it worth trying one coat of straight paint and see how it goes? as its a satin finish it doesnt need to be flatted back and polished so i'm guessing paint thickness isnt really that important?
Sam.
What it'd do if put a coat on the entire car, let it dry and if you can see through it slighty put another on.
If it looks like you won't have enough paint, thin it slightly.
Depending on the paint you want to mix between 10-20% thinners.
For example: 1L of paint add about 100ml thinners.
Brilliant Rob, ill order 2.5l should i use special thinners or just terps?
Thanks for your help
Sam.
You want proper paint thinners not white spirit or whatever.
Do you need hardener with it or does it air dry like aerosol paint?
Hmm you get those sort of time frames with every paint.
Best bet is just drop him a message to double check.
Ok, Will do :)
One NATO green breadvan coming up....
:D
