Door cards
Right I had my door card of today but since iv put it back on the door won't open! Maybe iv knocked something? I can turn the key like normal and the door pin goes up and down as it should.. It doesn't have central locking if that makes a Difference help would be much appreciated.
  • Views 685
Anyone willing to help?!
Pull the door card off as much as you can from inside and have a poke about, see if you can see anything loose. Sounds like you might have disconnected the handle from the release catch - it's usually a T shaped thing on the end of some wire...
Yes mate I did exacly that:( it's fixed now thank god.
