Anyone ever run Digifiz in a polo?
If you don't know what digifiz is, it's a digital dash system from the mk2 golf on the continent only:
have you ever seen this in a polo?
i quite like it in an 80s back to the future kind of way :oops:
  • Replies 28
  • Views 5.8k
i've not seen it done. but as long as you are good with auto electronics i dont see why it'd be an issue gear indicator looks hard though.
working ones of those tend to sell for more than most mk3 polos don't they? :D It's years since I used to frequent the clubgti forums but I seem to remember even knackered ones selling for rather a lot.
Anyway, no I've never seen it done in a mk3 polo but I can't see why it wouldn't work if you add the correct sensors. I'd be interested to know how the gear indicator works as that is something I'd quite like to add to my car, shift light is easy but I'd just like to see at a glance that I've got the right gear.
A good few years ago, I remember a silver Mark2 saloon running a GT lump that used to have astra Mark2 GTE digifiz style clocks in it. I'm talking years ago, as it was on the old polo-gt.co.uk website.
Anyone fancy a go? Ebay.
That is amazing lol. I was thinking the other day about making my own.
Get a backing plate and then all the different necessary gauges.
Might be my next on the side project...
it has a gear indicator? doesn't the R mean refuel?
Apparently the most difficult bit is finding one that goes to 8krpm and one that's working. Like you say, more than most mk3 polos cost these days!
I remember back in't day it used to be the done thing to put those Astra GTE digital dashes into Novas, so I don't see why it'd be impossible to put one into a polo in the same way. Although I do remember the speedos being comically inaccurate and slow to update (although maybe it's just the people doing such things to novas in the '90s/early 2000s weren't good at electronics!)
You can still buy them brand new from VW in germany and VW uk are making ways to get them over here.
Have a look on here http://www.vw-classicparts.de/shop/
According to the site you can buy the digifiz for 250 euros but I'm not sure those are up to date prices.
ah yeah you are probably right, just someone else saying about a gear indicator I assumed they must have one.... I'd still want to know how to make one without involving some kind of horrible switch array mounted around the gearlever!
Excellent, I would love to see one of these fitted to a Polo or even better, have one of my own!
Edited by MattLoaf
I'm sorry guys it is a fuel light i was wrong
seen a pic of one in a green one in germany so it must be possible (Will try find the pic)
must be alot of hastle though, but would be really cool.
i thought digifiz was the nickname for the engine management on late mk2s and mk3 gti's ?
Thats digifant ^^^^^^ same as GT's i believe
You should totally not have posted that link, considering my tax rebate just dropped through the door!
Haha! Youll thank me when you have one :-D
if i didn't need to buy a paddle clutch and an exhaust i'd be totally on for it!
i remember the car. in fact i went to look at it when it was for sale in 2005. it also had audi brakes fitted. it went well! the guy also had a black g40.
I've seen used ones selling for more than that before lol
if you got the correct loom for them I don't think it would be all that hard to wire in. Some of it would just be a case of matching the correct wire from the mk3 loom to the right wire on the digifiz loom, any thing that isn't covered in the mk3 loom (do the digifiz use a speed sensor for example?) You could just knock up a simple loom for and wire in its own simple fuse board rather than trying to some how wire it into the polo fuse box.
Id love one,dad had one in his MG Maestro 1600 when i was a kid,and i liked the one in a mates '89 Astra convertible although i felt the rev counter was a bit tardy when i gave it some beans.
The continent-only VW one there looks like it reads in kilometers only though (its in print by the readouts and its visible in the unlit economy light) and that's an MOT failure here.
well i disconnected the speedo about 7yrs ago anyway, so that's probably less of an issue for me.
  • 5 months later...
This is really strange to come across this thread as I've been reading about digifiz lately and have the english version of the vw manual etc on digifiz i've been reading, Really fancy one but there looks more wires to run it properley than a mk3 has in as standard :) I dont know it with out the MFA stalk and wiring if it will run fine just without the MFA options so you dont have to swap the stalk, getting the correct speed sensor, installing the clock alteration seperate panel, finidng / installing the wiring, getting the correct version of the board inside so that once they hit 150k you can reprogramme them with an eprom than getting ------- instead of milage reading etc and my main reason at the moment for not getting on I cant be arsed with KPH not MPH this seem the only thing that no one is able to get around
i put one of these in my old rallye and made the loom. took me ages and i still have all the notes to enable anyone to wire one into anything. speed sender is easily solved with a signal sender from a later polo. the rev counter is the bugger as it takes a negative signal for the pulse and not a positive like normal rev signals, you cant just put it on the negative side of the coil either- needs to come from an aditional wire on the ignition amp. so mk3s would need quite a rewire for that! mk2s less so. cannot run it without revs- oil light and alarm goes off unless it detects revs.
all the other features just take earths and positives from existing switchs like the rear fog and heated window.
looked the bollox it really did. i took it out again and sold it to fund my porsche wheels.
Sure saf posted a guide on polo3 showing how to convert a mk3 polo to run a mk2 amp and coil, would make it easier to get the rev counter to work I would imagine?
Kiz I would be interested as I'm sure other would if you could put up you notes? :) if its not alot of hassle :0
