vw mk3 golf/B4 passat and other vag stuff-dubfreeze
here is a list of all the parts i have for sale, some maty be interchangeable with polos, i dunno? will bring stuff to dubfreeze, but i the car is filling up.
bay window lower front wheelarch repair panel drivers side rear , £4
beetle 36mm rear hub socket 3/4" drive £5
PASSAT B4 saloon parts;-
central locking pump £15
air filter housing (abs code) £10
indicator side repeaters £4pr
no plate lights £3 each
heater control panel, with cover £15
ignition cowling £10
rear light (o/s/r) £5
rear light inner (with hole for boot lock) £5
headlight switch £10
instrument cluster and surround £20
GOLF MK3 -
diesel tank £20
front slam panel £20
front grille (no badge) £10
drivers headlight £15 with bulbs
rear lights std £20 pr
headlamp switch £10
headlamp switch with integrated fog £15
airbag steering wheel £20
airbag for above £10
drivers wing mint in LA3G classic red £30
passenger wing as above but with rustspot £10
rear hatch £20
bonnet £20
diesel driveshafts £15 each
diesel gearbox - mint no jumping out £125 ono
diesel radiator - vgc £20
twin radiator fan assembly mint - £30
Power assisted steering rack £30
power assisted steering pump £20
power assisted steering pipes £15
instrument binnalce showing 142k £20
centre console assembly £20
front seatbelts £20 pairSOLD
rear seatbelts £20 pairSOLD
space saver spare wheel 4 x 100 £15
golf steel wheels with good 175/70/13 tyres on £10ea.
sunvisors £5pr
interior light £6
airbag light incorporated into dash blank £10
front plastic inner wheel arches £10 per side.SOLD
dealer wallet with instruction manual £5
header tank £5
wiper motor and linkage £15
gearknob £2
handbrake surround(plastic-black)£4
handbrake lever assembly £6
indicator/wash wipe/hazard switch £12
igniiton transponder £5
central locking pump £15SOLD
rear "golf cl" badge £2
rear "golf" badge £2
parcel shelf black no holes and straps intact £10
parcel shelf beige no holes and straps intact £10
1.4 inlet manifold £5
gearshift weight £5
heater control panel £15
washer pump £2
pass side inner wing plastic cover £1
front wiper motor and mechanism £10
draper blink code reader, does golfs audis etc up to 1998 £10
door handles with ignition barrel and 1 key £40
3dr scraper rubber £7 ea
door lock assembly with c/l actuator £10ea
door check straps £5 ea
front calipers £30 pr
1.4 ecu £15
front engine mount (fluid)£10
power steering reservior £10
heater blower motor exc works on all speeds £20
front grille badge mint £5
n/s/r door bare £15 classic red LA3G
o/s/r door bare £15 as above
o/s/f door bare £15 as above
o/s/f door bare mulberry LC4P (3dr)
n/s/f door bare mulberry LC4P (3dr)
door glass, from a 5 door and a 3 door the 3 door glass ahs slight tint,the n/s/f glass on from 5 door sold £10 each pane.
OTHER
alpine 6x9 speakers£20
12v cig lighter heater,good for defrosting screens on aircooleds £12
golf mk2 steering wheel needs attention to spline, a bit wobbly when on a t25 needs filling £5SOLD
T25
front cab mat with walk through peice, never used £15SOLD
front springs std £20 pr
standard steering wheel £10
drivers static 1/4 glass £5
drivers round headlight backing bowls good cond £15 pair
instrument binnacle cover couple of broken lugs £5SOLD
n/s/f indicator body cut all around the indicator, for stitching back in £10
r/h/d sliding door inner sill,handmade, its the inner piece that the roller sits on, will need a little trimming to fit £20
several 185/r14 tyres with good tread £15each without wheel, £20 with wheel.
heater cover panel £10
vw polo 6N
1.3 AAV engine code camshaft lobes in good nick £5SOLD
i will be adding more to the thread as i find it.and removing it as it goes.
i will post items if required at buyers cost
i will bring stuff to dubfreeze, but i will require a deposit 1st,via paypal
items are located in manchester .thanks.
07565 360053 cheers ed.
  • Views 234
Pictures of the Mk3 golf centre console? Would you post?
hi, it is in excellent condition, and its complete, cant take a pic as camera is knacked, i will post it or collection avail at dubfreeze.
camera now un-knackered. any pics req? pm me.
i will check part numbers if reuires as some vw parts are the same across ranges, just the model number is different. :-)
