6n2 interior spraying
hello i got a 6n2 and i want to spray the center console collum, the windscreen vent and all the little vent plus the surround of the headlight switches white.
how do i go about getting all this out and what type of paint shall i use? hight temperature paint cuz of the heaters or just normal plastic paint?
thankyou
  • Views 3k
Hi there,
Its been a little with since i had the centre console to bits, i think there are some torx bolts behind the switches and blanks. Plastic primer and some hard wearing paint to keep the dirty marks off might be a plan. It should look mint!!!! high temperature paint might not adhear too well. Hope this helps. Neil
thankyou
I'm in the process of doing this myself- but black not white...
Upon looking at several other show standard cars who decided to remove the windscreen vent off the dash by breaking the glue...sticking this back on is a job in itself! none of the cars i've seen seem to have it sit right.
I've removed my dash completely...takes a while but you just need a few screwdrivers and the correct Torx bit.
the centre vent area is held in with 3x torx screws- one at the rear of the stereo/blank and then two are hidden to the left and right of the opening at the bottom either side.
Once undone you can carefully tilt this up from the bottom and slide it out of the dash.
Once you have it off the dash- remove the connector for the hazard switch and then unclip the switch from the panel.
You can then remove the airduct and looking at the panel you will realise you can also remove the vents themselves with the louvres...leaving just the front panel to paint!
the drivers vent will just come off once you pull on it...might be a screw holding the plastic underneith, but should still come off...again the same process can be achieved- remove the vent/louvres leaving just the face.
the switch itself comes out by pressing in the switch and turning it to the sidelight setting...then pull out.
the passenger vent just pops out of the dash and can be taken apart just the same...
What other parts are you painting?
cheers mate that helps alot
well I'm spraying the surround of the vents white and the fins gloss black but i dont no about the headlight dial as it might wear?
I'm thinking about doing some of the ash tray and center parts where the handbreak is but I'm not to sure yet what bout yourself what are you planning?
i sprayed mine white the glare in the summer is unbareable , i wouldnt recomend white
