Spraying front 6n2 badge inside
Hey Guys, i'm pretty sure somewhere there's a tutorial/DIY thread about detailing/spraying the front badge of a 6n2, can't find it though :\
i want to spray the insides of it a different colour to the front :)
thanks, Alex.
  • Views 926
If you take the badge out, flip it over, and get a knife, push it down the back (where the chrome ends and plastic begins) and lever it off.
The face of the badge comes off. :) Just primer and spray!
ahhh okay sweet, does it clip back in aswell yeah?
also, how on earth do you remove the badge thing? there's like a weird screw/bolt/nut holding it on? like a star or something ? (GTi Grille)
Yeah, it went back together. Although I wouldn't go nuts taking it apart, the clips are really fragile. If it doesn't, a little tag of super glue on the mating surfaces and it'll stay! :)
And I just use three fingers. ;) Put them in so that your middle finger is above the rest, support the grill with the other hand and pull!
It does take quite a tug though, so don't be scared. :)
thanks, Alex.
its easy mate i done mine white inside with a black vw just make sure u wash the badge before you do anything cuz the paint will react and fuck everything up so just be paitent with it!!
