Polish ? Spray ? Home repair ?
So I got everything but the doors painted at the shop. The car looks really good right now, but the left doors have a few scratches on them.
I'm not looking for perfection, just to repair most of the visible scratches would be fine.
What can be done here at home ?
Can "Metallic Gentle Polish" be used here ? Clean-->Polish circular Till Gone---->Wax ?
I also have a small can of raw LR5Y paint in a small glass, what is the best way to use it to cover the scratches ?
Here's the pictures with Flash on to emphasize the scratches.
Any info and ideas on making this look a bit better at home as last resort before total door paint job would be much appreciated. Thanks !
Uploaded with ImageShack.us
  • Replies 13
  • Views 1.6k
Good morning :)
They dont look that deep try abit of tcut that might get it out
All I have available is some Turtle scratch remover and Turtle metallic car polish, will these be fine ?
Use them on the scratches that you cannot feel with your fingers ?
That won't polish out, your down to the undercoat. Metalic paints are a bastard to repair as you need to get good base colour coverage, and then laquer.
Regardless, don't use t-cut on your car, ever. Use g10 or g3
So you reckon it's more bang for the buck to pay 80-100quid get both doors repainted ?
Thats good money to get both doors repainted. I know my place would charge a lot more than that!
If you're not too fussed about the final finish, just want the visibility of the scratches reduced, you can get a small bit of the paint you have on the end of a cocktail stick, fill in the scratches and polish it back after a couple of days.
Best bet is just get them resprayed if its only going to be £80.
Why not try it yourself? It's not too much work if your prepared to put the time in
Thank you for the inputs !
Try what exactly ? ^ ^
Can you describe the process in steps for me (summarize) so that these scratches would be less visible ? I don't care about perfection,some idiot will probably open his Civic door on me next time at the mall and create another ding.
Get some 400 grit wet/dry. Rough up the area around the scratch, about an inch around the whole thing. Masmnof this area with a soft boundary. Do this by folding the masking tape back on itself, instead of flattening it to the paint work. This helps it blend. Degrease it all with panel wipe. Spray your top coat on, do 2-3 lights coats. If you an get it, get 2k and hardener in a can. Be ware, once activated, you must use it with 24hrs it else it goes off. One done, spray on your laquer. Simples!
Edited by prankstar2003
Can anything be done with just some polish compound ? Can anyone take a picture and circle an area that can benefit from JUST POLISH AND WAX ?
if your still struggling to get these scrtachs out then give me a shout on 07815676234 i will talk you through the steps how to make it look good (own a bodyshop)
tbh mate i woudnt even try painting youself being light metalic blue it wont ever match specially if your gonna blow it in , just pay for it but i'd say get your own paint from a reputable good paint shop being a light met blue its a b*****d to match, my brother recently had a ding in his focus which is simular colour to yours. my dad paid around £100 for a litre (trade, but you wont need a litre) he did get a perfect match though
just try giving a tcut first and as above coktail stick-----cheap
