mk3 vr6 steering wheel in a mk4 polo
hi iv a vr6 with leathet handbrake and steering wheel will they fit my polo 6n mk4? iv got the leather seats and want it to match
  • Views 1.2k
The steering wheel will fit, just remember to leave the battery disconnected for half an hour before unplugging the airbag. Youl need to get the light reset using vagcom aswell :)
I don't think the steering wheel will fit, I'm pretty sure polo's and golfs are different, one has small spline and one has large. Even though the steering wheels look the same. I may be wrong but I'm sure I've read that somewhere.
vr6 will fit as i had one in mine. if your very lucky you might be able to get the anniversary one which is leather with red stitching. ni dont know but i think some used to fit ibiza centre consoles in and they came with leather handbrakes
edit spelling
Edited by dom604
Yep, Ibiza centre console bits will fit, they extend all the way down to the handbrake, rather than having a separate handbrake shroud like on a 6n.
However, only GTi's came with the leather handbrakes and from what I have seen they become very worn, certainly the one in my GTi is so worn its gone white.
Mk4 polo have the same lager size steering spine as mk3 golfs, so yes it will fit
Edited by McLOVIN
yep i have used a mk3 boss and airbag resistor on my 6n, so it does fit,
patchb dont think you need to reset the airbag light with vag com? I've never had to anyways!
