Arch pulling/flaring
Hi, wanted to ask if anyone had any experience with flaring there arches out? I'm not worried about the paintwork at all, or even the finish too much, but i need to get the arches to clear these superlites.
Reckon its pssible?
do NOT grind them trust me :lol:
superlites look sick btw
depends how well you want the job to be done...
cheap = scaffold pole between tyre and lip then slowly drive (probably won't flare enough)
expensive = get to a good body shop who will split it and add more material to cover the wheels
Cheers, na i wasnt planning on griding them, the only way i've thought it to pull the lip on the inside out, to maybe gain a little bit.
can you weld & have access to one?
I cant personally weld, but i know some one who can.
if you want them flared chop yours out and either reweld them angled so ther flared or weld mk1 golf arches on :)
