polo 9n seats
quick question to you guys on here how do you take out seats from a polo 9n (with airbags) and how do you remove the fabric ??? as i need to disassemble a passenger seat to get at the headrest runners due to one of them breaking whilst i was putting seat covers on it (this is on my mothers car)
  • Views 5.4k
Removing
WARNING
Refer to safety precautions when working on the airbag → Chapter.
– Disconnect vehicle battery → Electrical system; Rep. Gr.27.
– Slide seat forwards.
– Remove bolts -2- and -5- at back.
– Slide seat to rear.
– Remove bolts -3- and -4- at front.
– Separate belt warning connector -1- from coupling station -4-.
Notet Before separating igniter and earth wire, the mechanic must electrostatically discharge him/herself by touching door lock or vehicle body briefly.
t Seat is removed together with sliding rails.
– Separate side airbag connector -2- from coupling station.
– Attach airbag adapter -VAS 5094- to connector for side airbag.
– If airbag adapter -VAS 5094- does not fit in connector housing, airbag adapter -VAS 5232/1- must be used.
– Separate seat heater connector -3- from coupling station, if part of original equipment.
Unclip wiring harness for side airbag and seat heater (if installed) from seat frame -3-.
– Remove bolt -2- from both sides of seat and remove backrest -1-
Removing head restraint guides
NoteNo other parts must be removed in order to remove head restraint guides.
– Push padding down in area of head restraint guides and release locking tabs towards front of vehicle -arrow A- using a screwdriver.
– Pull out head restraint guides upwards.
Removing
Notet A backrest for a 2-door vehicle is shown.
t Depending on seat version, one, two or three padding wires must be fitted.
t The removal and installation procedures may have to be modified slightly depending on equipment variants.
l Head restraint removed
– Remove seat → Chapter.
– Remove backrest → Chapter.
– Remove head restraint guides → Chapter.
– Pull operating handle -3- from backrest release (2-door vehicles only).
– Pull off trim -2-.
NoteIf operating handle -3- or respective clip -1- is damaged, replace during installation.
– Separate beading strip -2- on bottom of backrest using a screwdriver.
– Unhook tensioning wires -1-.
– Roll up cover far enough that tensioning frame -4- and padding wires -5- are visible.
– Using awl -V.A.G 1636-, unhook padding wire -5- from tensioning frame -4- and pull off cover -1-.
– Pull padding -3- off backrest frame -2-.
Edited by nige8021
you sir are a legend thank you so much lol
