Taking apart FK Headlamps
Anyone done this? I'd like to take my black angeleyes apart to paint the grey plastic black.
The glue they use is of a grey colour- i've taken vw lenses off headlamps before but never FK...
Does anyone know what settings the oven should be on etc?
  • Views 852
i did this a few months a go and was proper scared about the oven way but its so easy. all i did was take the bulbs out (i left the angel light in and was fine) pre heat the oven... think i put it on gas mark 4, put them in for about 3-5 mins but check regularly then just seal again with bathroom sealant.
ohh cool...yeah i figured it'd be gas mark 4- and you didnt chip the glass or find that the glue was tough?
Its the grey coloured stuff they used on yours right?
ye it was that grey stuff on mine, pretty shit seen as mine got condensation in every time it rained. the first one i was getting scared so i took it out early so i had to force it out but the second one i left it in for longer and it came out pretty easy. a screw driver makes it easier as well. and i didn't feel like i was gonna break the glass at any point. incase you didn't no theres about 3 screws you have to take out before.
thats how mine ended up as well.
Edited by josh_h
where were the screws? i dont think my 6N mk4 lamps will have the same screws as yours...but i'll check.
As far as i can tell, theres about 4 clips holding the glass to the rest of the headlamp...then the lense is just held in with glue.
Unless of course you mean 4 screws holding the inner parts of the headlamp within the casing? :)
ye true could be different, if your had them you would be able to see them easily.
