how to take 6n headlining out
Same as title just wondered if some one could do a quick how to? which pillars to take off first etc... Sorry for the noobish questions.
Thank you all,
Tom
  • Views 1.9k
A Pillars come out easily. they 'snap out' and slide up/towards you (the bottom of the panel has a 'L' shape clip that can be a bugger to slide out sometimes. Also i have an alarm in my car so i had to unscrew the little clip's that hold the sensors in place.
B Pillars are slightly harder as you need to remove the seatbelts which are bolted in. HOWEVER you are able to take the headlining out by just un-clipping as much of the B pillar as you can and holding it back while you remove headlining. I'd suggest taking the panel out completely though. Haynes manual explains how to take seat belts off correctly.
C pillars are the hardest IMO. to get them out you have to take out the plastic side blocks that hold the parcel self in place. only a few screws and it just falls out though. easy peasy.
Remove all the handles, sun-visors etc, as well as opening the door and pulling the rubber trim off (it goes back on easily enough).
thanks very much :)
Your welcome.
Forgot to mention that the little "L" clips on the a pillars might rub and dig into the metal making it harder to get out. I forced one of mine too much and it snapped off however they still hold back in place perfectly fine without. Just in case you do as I did!
(oh, and the little rubber covers on the seatbelts brake easily too! really annoyed me they did!)
