Removing Polo MK2 Derby wing
It might already have been asked but I need to know how to remove the driver side wing on a mk2 polo derby. Already removed the screws into the slam panel, the bolts on top under the bonnet and the screws into the plastic wheel arch but it's still stuck? Anybody done this before? Cheers, Callum
  • Views 3.5k
there are 3 bolts in the arch that hold it on to the car by the door. They are covered in sealant so you have to clean all of that off first.
Found 'em, thanks a lot, would never have seen them otherwise, and that sealant is a bitch! Also is the front wing the same as a mk2 breadvan or polo classic? As mine is a Derby I was thinking it might be slightly different around the light?
I believe they are all the same... :)
Thanks mate, I'll get on trying to find a wing off an old MK2 then :)
