my TDi and fuel prices
Just a quickie
I've been mixing in the cold 1:10 of vegetable oil into my TDI , as my dads beed doing it to his chipped passat.
Its £3.13 in asda for 3 litres so near enough just over £3 a litre.
Since putting it in , SOMEHOW my MPG has shot up on town driving , Really do not know how unless its cleaned something some how i dont honestly know. I'm puzzled on that one.
So my question to you is?
Anyone know where you can buy cheap oil That’s under £1 a liter?
I fill up regularly and over the month il save about a tenner , a tenner is a tenner i suppose.
In the summer when its warmer il mix 5:1
Dont wait to go down the route of getting free used oil and filtering it as i dont want to risk it.
  • Replies 26
  • Views 3.3k
costco?
Lidl or Aldi? :biggrin:
£3.13 for 3 litres?
Thats £1.04 a litre!
Isn't the 9n a pd motor? If so its not really a good idea to run it on veg oil as it can damage the pump and injectors. Old stool indirect injection diesel can run on pretty much any thing, but with the modern type ones you have to careful mate
Edited by McLOVIN
backing that one up.
more modern engines just seem to be unable to handle veg oil on a consistent basis, it ends up leaving a build up in the fuel system, like fat in a fat buggers arteries.
or so i have heard.
best engines for it are the older ecu-free indirect injection engines found in cars like 306's and land rovers.
^x3 i heard it ruins PD motors, i looked into this
I also heard (but dont know why) that it does a good job of cleaning injectors
would i be silly to try this on my ford mundano. It uses common rail injection :s
well its a ford so for all we care pour water in and see what happens :-p
but yeah i think you can on the older ones, 1990's and such.
on a further note... using pure veg oil is usually inferior to using biodiesel from a supplier which is processed with correct additives for a healthy engine.
Edited by arron0909
Matt I wouldn't recommend it mate, common rail injection in general isn't really suited to veg oil apparently
to the OP, it might be a good idea to keep spare fuel filter in the car? Veg oil has been known to clean the shit out of the tank which can then be sucked through into the filter. If that clogs up too bad it can stop the car from running, better safe than sorry and all that
Edited by McLOVIN
Theres a lot about this on TDi club. Apparently its not even a good idea running biodiesel in these engines unless its a really small percentage mixture which to be honest wouldnt even be worth the hassle anyway these engines are great on fuel, i just filled up and had averaged 59mpg across a full tank
lol, Guy this subject seems something you seem to have researched extensively.
Wonder why that is :lol:
It pays for us Pikey types to know this sort of shit Neil :lol:
You only want to be doing this on older engines really as said above also with a Bosch fuel pump
wouldn't even run bio diesel on a PD... it does ruin them.
i looked at it on the t4 forum as I'm thinking of getting one soon,but dont think its its worth the hassle tbh.il stick to the pumps rather than changing filters all the time
also if you dont register to use it and your caught you will get done the same as if it was red diesel..
you can register and be allowed to use up to 2.5k litres per year without duty,they wouldnt tell if you used over imo,but it stops you getting fined if they check your tank
iiirc its the seals in the fuel system that get eaten away.
You dont have to register anything. Just use it. The whole point of that law was to stop HMC&E having to process a million forms from people running on weird shit.
A mate of my dads had a diesel frontera that he used to run on up to 80% used engine oil. He said it would run on 100% but it was too smokey.
All pumb DERV in the UK has a legal minimum of 5% bio-diesel already and that should be set to increase to 10% this year.
cheap motoring FTW :lol:
that was one of the main reasons i first converted my jetta to td, because you can run them on pretty much any thing you have lying around and cut running costs massively. although i never ended up putting that into practice because i found a source for cheap pump diesel :-p
Edited by McLOVIN
Cheers for the heads up guys
After reading the above i think i'll just stop , Having said that after driving it this week. my MPG figures have been so much better! about 10+ on what it normaly is. I'm due a service soon aswell.
is true, i seen it
i wouldnt bother youll destroy your pump.
i managed 63.5mpg on a full tank in my 1.4tdi i want more thou!
