2 kicker l5's, kenwood amp and wiring 900w rms 1800w max
i am selling 2 kicker o6s10l5 with box, kenwood kac-951d 1800w mono amplifier and the wiring kit. reason for sale is that i need money for another car.
Features: kicker Solobaric 06S10L5
•10" subwoofer
•SoloKon aluminum-treated composite cone with Santoprene surround
•Rigid steel basket
•Power Rating : 450W RMS/ 900W Peak
•Frequency response: 24-100 Hz
•Sensitivity: 86.5 dB
•Mounting depth: 6-1/16"
•Sealed box volume: 0.66-1.0 cubic feet
•Ported box volume: 1.25-2.25 cu. ft.
Kenwood KAC-9105D single channel power amplfier key features:
•1,800 Watts max power
•1 x 500W at 4ohms (20-200Hz 1% THD)
•1 x 900W at 2ohms (100Hz 1% THD)
•1 x 900W at 1ohm (100Hz 1% THD)
•Aluminium die-cast heat sink with cooling fan
•Power MOS-FET switching power supply
•Line level (RCA) as well as speaker level inputs
•Signal-sensing automatic turn-on
•1ohm load capability
•RCA line output sockets for adding additional amplifiers
•Gold plated RCA input, RCA output, power and speaker terminals
•Input sensitivity 0.2 - 5.0V
•Frequency response 5 - 20,000Hx (+0dB, -3dB)
•Signal to noise ratio 100dB
•Signal to noise ratio 75dBa (CEA-2006: 1 watt into 4 ohms)
•0 - 18dB adjustable bass boost at 40Hz
•Built-in variable low-pass Filter 50 - 200Hz (24dB/oct)
•Built-in infrasonic filter 15 / 25Hz (18dB/oct)
•Dimensions: 350W x 59H x 238D (mm)
•Maximum current consumption 57A
price is 280
Edited by jit
  • Views 408
Where are you located?
hatch end
Pics?
  • 3 months later...
SOLD
