Mk2 water ingress in driver's footwell
Evening all,
my polo mk2 has started weeing itself in the driver's footwell.
The water appears to be coming from the flap of metal which holds the return spring for the brake pedal (which you can see if you remove the tray under the steering wheel).
Best I can figure, that means it's coming from the battery tray. there's mild rust on the inside from where the water's been coming through, but no sign of rust or anywhere the water could get through in the battery tray. There's no rust anywhere behind the firewall either.
Anyone ever had this before? Do I have to take the tray back down to bare metal and then re-seal it with weld sealer? (Last thing I want right now).
I sprayed the whole area with some waxoyl type stuff in the hope I could prove that it was the battery tray, but the water keeps on coming through (although I've got a feeling there's less of it).
Thankfully it's not hitting any electrics or anything serious, but still v. annoying.
Any help appreciated! :-(
  • Views 850
Nobody's had any watery rusty battery badness?
best have the battery out and clean it all back so you can see whats what , very common for them to be holed there
post some pics up once its cleaned well
