Genuine Polo G40 - SOLD!
Here we have for sale my Genuine Mk3 Polo G40, with a select few modifications
Genuine G40 Grey metallic, non sunroof.
K reg 190,250 miles on shell (to date - 12/12/2011) I am using it daily and do 250 miles mon-fri with work.
Engine:
Engine replaced for a fully standard 97k standard PY G40 (With Stamped Full Service History), fitted with a new continental contitech cambelt at time of fitting (11k ago) (to date - 12/12/2011)
Oil & Filter Changed at 4k, 8k (miles since engine swap) and due to be changed in the next month. Always used Synta 10w 40 fron VW
Due to fit Bosch W5DPO spark plugs - these are new and discontinued, but came in the original VW boxes, had these sitting on the shelf for years.
Jabba Stage 2 G-lader
Standard Air box & Boost Return Setup
Samco Blue Boost Hoses
Polished (Top Half) & Ported Throttle Body
Full Standard G40 Exhaust (Backbox replaced 3 months ago)
new pattern exhaust manifold and VW downpipe gasket fitted 2k ago (to date - 12/12/2011)
Fitted new thermostat, g12 plus plus coolant, fitted 2k ago (to date - 12/12/2011)
Suspension/Chassis:
Powerflex Inner & Outer Track Control Arm Bushes
Powerflex Anti-Roll Bar Bushes
New VW Rear Axle Bushes
New Front Wheel Bearings. Top Mounts & Rear Wheel Bearing Fitted 3k ago (to date - 12/12/2011)
60mm Spax Springs on Front
Standard Suspension & Springs on Rear (60mm rear springs supplied)
Brakes:
239mm front discs with VWII calipers (Painted red)
Rear shoes replaced 2009.
Goodrich stainless Braided Lines throughout.
EBC Drilled/Grooved Discs
Greenstuff Pads
Wheels:
13 Inch Standard G40 BBS RA's with 195/45/13 Continental Contisports
Interior\Exterior:
Roof wrapped by DKnight in textured black vinyl
Pressed Plates
New gear gaitor
leather VW gearknob
Blue led bulbs in clocks and dash.
VGC interior
Paperwork:
I have over 70 reciepts from Sinclair VW along with around the same for GSF and local motorfactors.
Full Stamped Service History For the Original Car/Engine
Original Service Inspection Report for the Car
Full Stamped Service History for the Replacement Engine
Nearly all MOT's (Missing circa 3-4)
3 Previous Owner slips
All original manuals and VW documentation, including the Polo G40 supplementary booklet
Niggly Bits:
Boot lock is stiff but opens from inside
Couple of rust spots, lil bit on drivers door bottom - pictured below , these are surface rust and very minor considering the cars milage
laquer peel on roof so vinyl wrapped
slight scratch on passenger quarter panel
Could do with a battery tray repair
MOT - Jan 2013 (Will be retested this month)
Tax - End of Jan 2012
Looking for £1,995
Edited by grungeisdead
  • 4 months later...
  • Replies 82
  • Views 10.5k
Still here!!!
I'm feeling rather greedy with three boosted motors, someone else needs some enjoyment!
Would you be interested in a p/x with a Mk4 1.0? haha
dependant on cash monies, i could be interested.
talk to me!
let me know if this gets broke please ill have the engine off you in a second, if not good luck with the sale
i would love to have 2grand right now :(
Is that the only rust on the car?
Is it just surface rust or will it need more work?
Also would you take px for my 1.6 6n forsale with the ronals, plus cash your way?
Edited by polomanphil
pm me your best cash offer plus your car and ill think about it
just surface rust, battery tray would probably do with attention, but all round every window is fine, as the the sills and valances. the jacking points will pass the mot in january and would probably again in 2013, but could do with some love.
the only giveaway the shell has done 183k is the clocks! its a credit to jason (g-spot) who owned this g40 for around 6 years
Do not let the pics of the rust put you off. They are very honest pictures and are no worse than when i owned the car almost a year ago now. Didn't put me off buying this beauty one bit and would be easy to sort if you wanted.
Nice shell and an awesome car that got compliments everywhere it went. I miss it.
Thanks Barney, much appreciated mate!
I'd much rather have pictures detailing all the niggles and bad spots rather than try and hide them.
cant believe noones even come to view it yet, poor g! I'm still loving driving it, its an absolute pleasure with a standard exhaust and suspension on!
car was given an oil change the weekend, castrol gtx 15w40 semi synth and a genuine g40 oil filter!
will get pics up on the stamped up service history booklet tonight
Forgot to add that the car does just over 100 miles to 15 quid as I do two days to work without fillin up and its a 50 mile round trip!
Still here, still not been viewed by anyone!!!
Only got a week before I go on holiday, so might take a decent offer, if someone actually comes and looks at the car, drop me a PM!
i have the money and prepared to travel, but insurance is way out of my legue (18 with 0 ncb) :@ :@ :@ :'( good luck anyway
Buy it and do a full oem resto! By the time you've got a couple of years ncb under your belt a standard mint g should fetch a fair bit more than as numbers dwindle. Plus its a good chance to own a bit of true vw history
What I group insurance is it?
No idea mate, I pay 700 odd 26 2 yrs ncb but a few claims recorded.
Now without alarm as yesterday the starter motor bit the dust and I was certain it was the immob. Hopefully it will be sprted bwfore I go on hols. Got a couple of spare starters to try
How about my derby and my left testicle? Its the size of a tangerine!
as much as id like a tangerine sized bollock (makes for good bargaining) i'd rather take the right one, and your gf's left breast.
failing that i would px against another old polo, so i (and my housemate sally) can potter around in it
i have a mk 3 polo white chalkboard roof bonnet and boot stickerbombed door cards. its a 1.3 with yr mot and 6 month tax will u do a deal?
pm me with more details and what you think the car is worth and we can go from there
please keep this till april :wink:
Hater! Worth a try though. If I wasnt saving up for a holiday then i'd snap your hand off for this!
Aahhh!!! I was going to pm you an offer on this and part ex for my GT. FUCKING INSURANCE!! Cheapest quote is 2300!
Do you still have this? Thanks, also would you be willing to drop the price couple of hundred or so.....? :?
Still got it dude. Someone needs to buy it before I get myself in to debt buying it.
