Steering column size
I took my wheel off to check the spline size to get a boss ordered up. It was 25mm, however it looked like an adaptor with the 17mm spline on the inside. Is this a genuine VW part or what? Don't want a cheap aftermarket P.O.S. to shear off while I'm driving :p
Anyone seen anythin like this before?
  • Views 638
Yep that is what VW made.
Makes it easy to switch between small and large spline if you ever need to :-)
Thanks mate, just what I wanted to hear :)
Any idea why they did this rather than just using the small spline?
