6N AEE bike carbs, dyno result...
Right chaps, went to collect my Polo earlier from having the following done:
Fit 272 degree cam.
Fit new crank pulley and dial in with cam.
Fit new belt.
Re-fit aux belt, pulley and timing covers.
Fit dyno jet kit and mild setup on carbs for running in the following: new big end shells, new rings and new piston on number 2.
It made the following on the dyno on purely a mild setup so i can run the engine in:
What are your thoughts everyone? Please no slating, constructive criticism is ok though. It's running a high lift cam, head work, 4 branch, decat, full system, R6 carbs, adjustable timing gear and the dyno jet kit. The chaps told me the ignition is currently very far retarded and the fuelling is light so i can run the engine in. I'm hoping for 130bhp ish when finished, do you think this is achievable?
  • Replies 28
  • Views 8k
should be if you get everything right but that figure is impressive
Thanks.
I've heard funky things about their rollers... but... with what i have done, i think that figure is about right?
I mean they said the ignition timing can be advanced quite a bit more, and that the needles/jets/fuelling can be messed with a lot more, but it's mild setup for running the bits in.
It's already 40bhp above standard so i am happy, although maybe wrong cam choice for an engine that isn't made to rev hard? The bloke reckons it will rev a lot harder that they put it to, gunna need a new rev gauge haha, standard one tops out around 6,500rpm i think.
Good stuff, glad it's all running now :thumbsup:
Mate, couldn't have done it without you, what's your address?
PM me, thanks is in order.
Ed :)
Good result! One of the most underated conversions in my humble opinion. I dont think they are particularly "revvy" engines though, id be more inclined to go for tractability and low down grunt. Cheers Mark
Not bad, was going to do the same to my 1.6 engine but decided to sell it in the end.
Don't think it does the engine much good revving much higher than 6.5/7k, hydraulic tappets don't like high revving, could put a mechanical head on 8-)
Thanks a lot mate. Considering it's on a mild setup should be better when it gets a real hard tune. Tbf, i've reduced some of the weight too, and the 6N can't be a particularly weighty car anyway, so i'm hoping for a little street weapon. In all fairness, much more power than that in such a small car and you can't put it down anyway. My mate runs a Charade turbo with approx. 170bhp and it either spins the wheels or throws a bottom end shell lol, shame really, but it isn't made for it.
Thanks bud, yes i agree, not much higher than 7k, that's prob why my civic (redline at 8,200 and that's tame for some civics) is a mechanical head :)
Impressive! Well done!
cant say i agree with that, I'm running 170 ATW, 150 ATW in a lighter polo with a worse standard suspension setup than a 6n and it absolutely flys.
decent figures tho, a chap got 138bhp from an AEE, details in the bike carb setup thread
http://www.clubpolo.co.uk/forum/index.php?...t&p=1855301
Wow, this is nice to read! I'm currently completing this myself, and was hoping for 100bhp at most!
How do you plan to run the engine in? Mine has been fully rebuilt, and I was concerned about wear with such lairy fuelling.
Well done mate!!! I know youve been building this car for quite a while now so am pleased for you!! and from a 75bhp engine no-less.
That is amazing...
I also have the AEE didnt realise these figures were anywhere near possible....
Could you possibly PM me with parts etc? or do you have a build thread? very interesting
Well done mate!
That is amazing...
Well done mate!
Thanks guys.
The engine will have 500-600 miles on mineral oil at low revs.
I'll try and get parts/build up when i can cheers.
Fair point, there are plenty of small/light cars that are designed to put the power down, and do it well, just my personal experience i suppose but guess that doesn't count for all motors out there :)
good work mate - I ran the same engine with a lesser spec in my mk1 polo and that was great fun... probs more usable in your car due to the fact you can go round corners and brake!
looking forward to seein what it'l do with some advance and a decent amount of fuel in it!! seriously knowing the difference a bit of advance and extra fuel can make I reckon you will be really impressed when you get it set up after run in...
So you reckon the advance and more/correct fuel should be a good improvement?
He seemed to say it could be advanced a lot more and the fuelling is light too. He was interested to see what it'd do after run in.
Only thing that baffles me is... my torque peak is at an almost standard figure??? Approx 103 lb/ft... anyone got any idea why? Should the final setup sort that?
Edited by leeds_finest
I put an AEE in a MK2 several years ago and didn't know how to fuel it,someone i knew said i could try sports bike carbs and i thought he was off his tits.
I asked no more,but i put them all together and the result got me lovin a car like i never had done.
I've had hundreds of cars. But i stopped trading when i got the Polo because i was too busy working on it to trade cars..
Result was a bike carbed AEE i couldn't help but rave about. Efficient with low-rev power,and no engine I've ever built has sounded as good. Get it running right and its superb for a daily.
If you wanted to beef up the bottom end,you can use a 1.4 block and cambelt,and 1.6 16v con-rods. Though you may as well use the whole 16v if you're on carbs - you'll never get 8v valves to cover the combined size of the 16.
Well i'm glad that everyone speaks highly of them tbh. So much blood, sweat and tears has gone into this engine now that i really just want it to be fantastic.
I fitted the cam belt wrong (learning curve), shagged a piston and four valves running the high lift cam, then rebuilt engine and head, re-fitted everything and snapped the cam belt because an engine mount bolt of all things worked loose and fell between sprocket and belt (also rendering sprocket 'burred' and useless). Finally back together now with new parts and the cam dialled in and just can not wait to have it setup properly after run in.
Tbh, i loved my standard 8 valve. Yes, it wasn't fast, but the torque pinned you back and it just felt great to drive low down, effortless push. Never really been a fan of the 16v's as the majority, not all, but most VTS type cars need revving really hard to squeeze every last drop out and as the powers spread across more revs, never particularly found them amazing to drive, although i suppose the VTS itself is very understated, my mates have had loads. I know for a fact my mates standard 6N valver feels gutless compared to a standard AEE, but that;s because of the torquey AEE, in actual fact the valver is prob quicker.
I suppose mine will drive more like a 16v now it has the high lift cam and will shift the power further up. It sounded ok when i took it up my road and back, but couldn't open the carbs up much due to new shells, and didn't rev it past 3,000. Hoping i've got a screamer when it's all finished, that's the main thing about carbs for me :)
Mikey what do you reckon to the power reading? I'm pleased with 117bhp considering the ignition is retarded and the fuelling is light for run in period, and considering it's cammed but only took it upto 6,000 for a quick reading,i can imagine between 6-7 grand there will be more power there, the power curve seems to carry on strong when they let off the throttle.
HOWEVER, what do you make of nearly standard torque? Bit disappointed tbh, or is it a case of anything and everything could change when set up properly for maximum figures?
Cheers :)
Great work mate.
I'm fitting gsxr 600 carbs on my 1.4 8valve with adjustable fuel reg, 4,2,1 manilfold with straight though exhaust. :)
I'm hoping for about 90bhp from that.
Bet your looking forward to the proper set up when they've been ran in.
But amazing work on this and good output.such a clean engine bay aswell.
Put some engine bay pictures up??
Dan
doubt you would get 90bhp mate.
More like 75 on well setup carbs.
Great work mate.
Dan
Speculation can cause these disagreements lol. Go off previously achieved or wait for your figures on a print out.
Tbh, going off previous, club polo member 'Goose' picked up around 90bhp total with 4 branch and GSX carbs on his 1.4, so easily do-able on a good setup i would have thought.
Anyways, Dan, thanks a lot mate, i put real effort into keeping the bay clean and tidy... a lot of messy elbow grease has gone into that trust me. I'll get some pics up when i can, i hope the bumper is treating you well, i like to meet other club polo members, sorry that work took priority on that day :(
Ed
AEE cam is profiled for torque,so you're always gonna do well not to loose some with another cam.
I recon the 1.4 should get 90bhp on factory cam.
Ahhh ok, i assumed it was just the way the engine was, didn't realise it was the standard cam :)
Then engine is torquey anyway, due to the stroke length. But obviously the cam is a factor too.
Apart from the oil your using, and restricted revs, how have you tuned the engine for the running in period? You talk about the light tuning of the carbs. What has been done here; just smaller jets? I'm about to run in my aea (1.6) on bike carbs too, and I'm concerned about excessive wear due to the improved performance. I see your looking at a rev limiter too. Personally I'll go by my well trained ear! :lol:
Edited by prankstar2003
good results :thumbsup:
intresting to see what it puts out when all dialed in
