mk3 tail gate, and quarter light
i have a GT project and the boot is rusty so i have got a new one but i have never attempted to remove one anyone know how to do it ?
same story i have to replace the door rust again anyone know how to do the quarter light done pritty much everything else before just want a heads up of what to expect
thanks rob
  • Views 1k
thanks rob
dunno about the door. the boots a breeze, open it, remove the rubber seal, heat up the headlining so it can be pulled away, then there 2 13mm (iirc) nuts to undo on each side on the hinge, then undo the struts/wiring and it's off.
awesome chears mate when you say heat it up what with ? will a lighter do ?
also when you have taken it off and put the new one on what do you do to keep the head lining stuck up ?
thanks rob
So why did you make me put it back on then? :p
Heat it up with a hairdryer dude :) And its not that hard, but you'll need a couple of people to hold it for you.
Also Rob (Davies) did robbo tell you about his accident taking off the door on that 6n we broke? :lol:
thanks chaps mint advice
a light would probobly set your car on fire mate. use a hairdryer
because i'm lazy, and no he didn't
any one know anything about he quarter light ?
