Seatbelts
hey i have had problems with my seat belts in the front of my 6n, they are loose and do not retract when unbuckled. i was wandering if anybody knows how to fix this problem??
  • Views 670
Take them out completely, it might have got stuck a little within the B pillar. You can test to see if the retracting works or not for sure then. If not, see if you can get a cheap set that work from the 'car breaking' section of the forums.
my 6n drivers side belt just stuck solid the other day?!?! no idea how or why? so took it out still the same stuck solid so had a ride to the scrappy 18quid but its sorted now
