what haynes manual for 1.4 16v afh
Hey anyone one know what haynes manual covers the afh engine is it the 2000 to 2002 one as i dont want to buy it to find out it covers a different engine.
let me know
Peter
  • Replies 9
  • Views 3.9k
As far as I am aware there is no Haynes manual that covers the AFH engine..
thats pretty crap is it similar to another polo engine say the 1.4 16v that came in the 6n2 or not as the haynes manual for that says it includes the 1.4 16v.
There's little difference that matters,the head torque settings are the same and the universal torque settings are just that,its mechanically the same as the 1.4 8v although the big end stretch bolts are the bigger size found on the 1.6 AEE - i used my Golf/Bora and Scirocco Haynes manuals as well with things like that with 6n engines.
Its all the same design as the 1.4 8v but for another cam and row of tappets,the whole bottom end is identical but for minor details with the rods and pistons,cam drive system is slightly different but works/fits/adjusts the same,again its all detail differences that don't matter in most cases.
The AFH cam timing dots facing eachother at head deck level is the only thing missing they really could and should have mentioned,perhaps just on the end of the petrol engine section.
Otherwise there are a few bits here and there in the fuel system what with having a different design of inlet manifold and all that,EGR valve for those who haven't binned it yet,but otherwise i guess it just isn't different enough to have warranted another section for it in the Haynes manual - unlike the Golf book where there are two completely different 1.6 engines,having a section each.
And other differences like the bigger brakes aren't gonna make any difference to the info needed for servicing/overhaul.
to be honest i only really wanted it to get the timing right and the torque settings and see if there was anything else i could do etc but il have a look at getting the 1.4 8v one then.
thanks mikey
now then, did you manage to source any info for the timing? as i'm having a similar problem finding any.
nice cheers
thanks nigel that same stuffyou sent me a while ago that you posted here helped me today as i finally rebuilt my afh engine and the timing looks spot on now took me a while to do though and good luck arron its not too hard to do mate.
