6n2 Electric Window.
Hi guys, i know there are a lot of threads about problems with these but i just want to clarify something.
Should the passenger switch allow the window to go all the way up with one touch?
I can do that from the drivers side but not the passengers side. Should there be a '2 stage' switch which allows it to go all the way up with one touch?
  • Views 1.3k
Yeah it should do it on both sides the one touch thing mate
Right okay, thanks for your help mate :)
Gonna be the switch that is faulty I'm guessing?
The passenger side only has a one way type switch.
The one touch feature works from both switches on the drivers side; but not the passenger.
basically it could be you are car isnt programmed for the switch. basically turn the car on ignition and hold the switch completely down until the window fully opens (whilst still holding it down) and then fully up until it closes. then u should find that you are automatic one touch thing will work.....hopefully
oh and you have to hold it down for about 5 seconds or so each way!!
hope this helps
