Spray Glue?
Helllloooooooo
I did my headlining and pillars not that long ago and its sagged to shit now and I'm looking at what glue to use, I've seen '3M Spray Mount' 'High Adhesive Carpet glue' Etc...
So what have you used? Preferably not that quick dry stuff...
  • Views 1.4k
I used "Heavy Duty" spray glue that I got from hobby craft, it's the stuff it says you can use for putting those square vinyl floor panels people have in kitchens down with.
Been on for about a month, no sagging what so ever yet but hasn't had a hot day to deal with. (Although I have had the heaters on full blast and warmed the car up as much as I could to test.)
My Tip:
Make sure you pin the cover you use back with duct-tape (on the back of the headlining, obviously) and pull it as tight as you can. Hopefully if the glue is to warm up and lose it's grip the tape will hold the cover in place long enough for the glue to cool back off and harden again.
Edited by Liquidice
Awesome, but there isnt a hobbycraft near me, and they dont sell it on the website :/ Anyone else?
Trim fix is meanmt to real good, you need something that can take high heat temp. I used the hobby craft stuff in my olf polo and after a week in the summer the door cars started to sag. Got some trim fix and redid it and never had a prob.
Cheers man, ended up getting the same stuff from a shop appreciate it!
dunno if this will hold out due to heat! best stuff apparently (and that I've used) is trimfix spray adhesive!
the best thing to use i've found is contact adhesive you can get it in big tubs that you can just paint brush on, sticks better than any spray adhesive and is heat proof, used it on mine and i know a few others that have done the same, I've heard no complaints from any one !! the linkie posted it a small tub but you can get up to 5ltr tubs and its very cheap !!
clicky here to see
