how to smoke your headlights
here is a quick guide to how i tinted my headlights on my mk3 polo.
i would presume it would be the same for all other marques i would advise you to take care and i'm not responsible if you mess it up, neither is this forum!
anyway, here is a before
remove headlight from car and take into your house like so
place into oven, on a low heat so you dont melt the blooming thing
i placed onto an oven tray and then when i took it out i was able to keep it in the tray and work the glass away from the reflective part.
you will eventually have this
i then used masking tape to protect all the area that i didnt want to be painted
(i made the masking tape a little less sticky by pressing on the sticky side with my fingers, you dont want it lifting up the reflective chrome! )
find a loft or an open area to get the spray paint out and give it a wizz over with
i would suggest you use a matt paint or high temp paint
peel off your masking tape carefully!
this is what you will end up with
replace the glass onto it and it should come up with this.
now make sure you seal them back up and give them time to seal properly.
i used some black sealant i found at a hardware shop.
note that i painted the bulb holder too!
and here is the finished result
you can go a bit crazy, i have a set that i would probably only use at shows and meets during the summer that were similar but a lot less chrome has been protected.
which look like this on the car
or red
anything you fancy.
it is such a joey mod but it looks brilliant on the car, like i said i would only use these during our longer summer days.
enjoy
hit up some pics of your own when your done :)
  • Views 1.2k
erm yeah, just a tip.. Don't EVER use masking tape on the reflective bit or you'll end up ripping half of it off like in this picture stolen from above:
Use a paint brush, save yourself a lot of hassle as you'll never see the brush strokes through the glass anyway.
i forgot to add the indicators are plastic so they could melt in the oven, i wouldn't risk it so i painted them by spraying the chrome part inside very lightly, you could in theory dip a paint brush into it and paint it that way, just be careful not to paint the actual lens!
I have a few pieces of advice to any one who wants to attempt this.
1. buy a second set of headlights
2. leave them in the oven for 10-12mins @ 60-70 degrees C
3. leave the headlight you are not taking the glass off in the oven until you have the glass off the first and are ready for it.
4. if the glass isn't coming off relatively easily, put the light back in the oven.
5. be patient.
6. when painting keep as little paint on the brush as you can, to avoid drips and runs. the reflective surface doesn't take kindly to having paint wiped off it.
7. take your time and be careful.
