serious water probs
Well was minding my own buisness today @ work just finding were to run amp wire etc. Passangers side pulled back carpet all looks ok just having a look about pulled back thick rubber mat that looks to be sounds proofing. Grrr soaking wet driPping all of it. Arhhhh isqueezed it might as well just squeezed a soaking cloth. God noes but it rining wet throught. Now heater matrix leak didcross my mind but hmmm
Car always mists up at front only on a morning and night. Water prob
Just woundered if anybody else experienced same probs.
Or what to check
Tom
Drivers side carpet bit wet but I think that cos my boots were damp when snowing and most days at work so I can sort that
  • Replies 13
  • Views 1.6k
What Polo is it mate...
or sorry mate forgot to put its a 1997 polo 6n 5 door 1.4
tom
I have/had a '97 6n 3 door and when stripping it I too noticed that the mat stuff under the carpet was soaking wet...
My car did sit in the previous owners garden for over a year doing nothing, so that may be the problem. But even sitting doing nothing it should not get that bad with water?
Edited by DavidTiger
Sunroof, windscreen. My 6n used to leak in the footwell on a regualr basis drains on the sunroof.
Come to think of it the padding/sound proofing stuff or whatever it is (lol) from the sunroof was a bit wet aswell. Not as much as the floor but still quite a bit.
dunno aint got a sunroof. i just cant quite get my head aroun why its soaking wet. just aint right. thing is what i want to do it rip it all out dry it and check all the drains etc and heat matrix for leaks i just wounder how hard it is to get sound proofing stuff out.
remove all dash etc etc ???
tom
hmmm
what did you do with yours been soaking. did you find were it was possibly coming through??
tom
I would never have noticed it if I wasn't stripping the car, and because I was stripping it I never investigated why it was soaking..
I don't think it was the heater matrix, as when I removed it it wasn't showing signs of damage or leaking etc... My only guess is the sunroof since it ws wet a good bit aswell..
hmm will have another look. need to get to the bottom of it. cant leave it wet will have a look at all the drain away places roof etc etc check there not blocked. check all the bungs. on the other hand i have a small feeling it might be the pipe to the rear washer. the pipe runs throught bulk head and then down side of car behind all plasics. all i can think is when i spray it lashes water everywere doesnt come outta that jet very fast like there possible could be a leak not alot of pressure but on the other hand the jet could be blocked up lol, hmmmmm
well I'm a happy man now. had to cut a small amout of the sound proofing out underdash rotten pulled a few more things out found water leak got jet wash and sprayed around screen near back of bonnet found its coming throught the rear washer jet pipe work. some one in the past had fitted a aftermarket alarm and run wires throught grommet were wash pipe is so it wont seal water leaking down pipe and wire and poring in. so gonna let it dry out and silicone it alll up tomoro. on the other had tho i gonna hve to remove seat and carpet right back cos the whole carpet soeaking wet all way back (bad times but least i hopefully got to the bottom of it
tom
Seems to be very common, looks like mine comes from my door (passenger side), runs down side of door over the speaker cover and drips on to the carpet, I'm waiting till the summer to sort all mine out so i can strip it out and air it.
Yeah seems to be well siliconed it today so fingrs crossed it be ok. Will check tomoro. I also sealed door back up. It didn't leak but to be on safe side. Now just need to dry floor out. A gold fish would have a whale of a time on my floor right now. Live quite happily lol
Tom
Same as mine.. I can't work out where it's entering from. When i first got the car I was getting massive puddles in the passenger side footwell, clearing the Sunroof drains sorted that.
