Maiden Voyage, R6 carb'd 6n...
Did the Maiden Voyage in the Polo Monday/Tuesday.
Took it upto Durham via Leeds from the West Midlands and back to rack some miles up on the new engine.
Consumption on the way up was shocking, i'm guessing due to rings bedding into bores etc. Also, was trying to do 50mph in 5th gear and the engine didn't like it so much because it's running a different cam.
However, on the journey home (approx 200 miles) and for the rest of the tank of fuel with round town driving, the car achieved 32.5mpg combined. Quite pleased with that figure.
The car itself held out well. No oil loss, no water loss, no exhaust smoke, no warning lights... the only thing that was a nightmare was the wheel alignment as i didn't have time to get this done before i left - all sorted now though :)
Thanks :) Ed
  • Views 1.4k
your set up on this is awsome mate, i came with polodan2009 to pick the bumper up and i was gobsmacked, whats the take off like bet its quick
Hi mate hows it going.
Thanks a lot bud, i don't think you see carb'd AEE engines in 6N's so much, more like mk2's and mk3's so it's a nice change i think.
Tbh it isn't great atm. I can't give it full licks because:
1. Clutch seems ok but release bearing noisy as HELL.
2. Still only done 500 miles since rebuild.
3. Still running on mineral oil (changing tonight).
So i haven't really kicked it's head in yet. Also, it's got quite a fierce cam in it, and it significantly loses low down power/torque, so it doesn't drive like a normal AEE 6n tbh. I gave it one quick blast to about 6,000rpm last night and at about 5,500rpm it seemed to pull really hard and started to sound different...
...much reminded me of a VTEC Honda lol.
Such terrible fuel economy is not normal and indicates that its very unwell. I'm sure the cam isn't helping but i suspect the carbs need attention too.
Obviously you need to take great care whilst running-in,but id still get the carbs looked at. Especially if you soon find you're getting sooty plugs.
It's fine now, it was only really the first few hundred miles.
It just seems to sit more freely at say 70 in 5th than 50 in 5th, guessing it's closer to the power/torque band.
32.5 combined isn't terrible is it???
...and i know it's running a little rich but hasn't had a final setup yet, it's only a rough guide to get me around on for the time being.
i wouldn't have thought on any modified engine that 32.5 is terrible...just expected! haha sounds good work either way!
get it set up properly, over fuelling can wash the bores and just generally fuck your engine, lol.
Well i would've thought it would achieve this as standard, so with a much greater power output you can't complain really?
Agreed, i've only done 600 miles since having it back on the road though, and it'll go back before 1000 miles most likely.
