Boot lock locked
Ok, firstly, my searching skills are as good as my singing skills, so I apologise if this has been mentioned elsewhere.
Can anyone suggest a way of getting my boot lock to unlock? It used to work, though had a few problems with it where it wouldn't unlock from time to time, then gradually it has stopped working completely :( put the key in, and nothing happens.
I have sprayed it with WD40 to try and free it up, but still nothing.
Is there anything I can do? or does anyone know a way of opening the boot from the inside so I can actually look at the lock to see if everything is hunky dorey :lol:
  • Replies 11
  • Views 1.3k
Just the same as my punto lol i have to climb over the seats and pull the switch across :/
I'm half way through fixing my mk2f one and with a guess the internals are probably not the diffrent.
on mine all the brass slides inside the barrel are corroded and I'm sitting here currently having knocked them out sanding them clean and soaking them in wd40.
Same as mine... If you only use it now and then you can take plastic pannel off on inside and there's a little rod you pull to the side and it pops open
^^^I had a cable tie on the end of the rod (mine was jammed open) so I could reach it from the back seat rather than trying to reach under the parcel shelf. :lol:
But all is now well, Managed to rebuild it all and for the first time in 3years I have a working lock.
All the springs for the tumbelrs were seized, the tumblers also seemed to be out of line with the key (which was wierd as it had worked well before it jammed) so reconfigured the tumblers and the lock body spent the night in a sonic bath to get the springs released.
Edited by Cymro
I have the same issue on my 6n mate, found just turning The key half way to unlock and then pulling the handle works everytime.
I don't know what year your car is but I have had the problem a couple of times with my current Polo.
Managed to fix it a couple weeks ago with a temp job.
Basically a pin that holds the mechanisum together had worked its' way free, we used a screw to reattached the bits and it's working fine again now.
still finding myself crawling into the back and pulling the seat forward to get into the boot though :-D
Well just to let you all know :) took the lock apart and it appears that some of the springs are either missing or filled with crud so it can be turned once, but the little bits that slide out to let the key in, but wont go back in, so it will be new lock barrel time now :)
I shall now have 3 keys for my car :lol: door, boot and ignition :p
How did you guys manage to actually open the boot with the lock bust (6N)? I've tried doing it from the inside but I can't get to the lever because of the plastic cover and my cover doesn't seem to want to come off without opening the boot. Awkward situation? :S
You need to remove the panel on the inside of the boot.
Remove the screw from inside the handle (can see it if you look straight into it from inside), mine didn't have one :lol: then gently prise it round the edges and it will come loose. I found taking the two parcel shelf holders out made it easier to get out. Then you can get to the mech that actually releases the boot and push it towards the drivers side and POP its open :)
Can be a sod, would get you a picture of what it looks like but it's too dark now :doubt: Hope this helps CWA :)
Edited by NEPolo
There should be a rubber ring which sits around the lock barrel and seals against the push-button. These wear out/perish over time and need replacing, especially in boot locks where the dirt/crud gets sucked up as you drive along.
WD-40 will get you in but wont last for long. The only way to make a repair last is to strip the lock down with the key in the lock, clean the barrel and the brass tabs, re-assemble using copperslip and a new o ring. Better still, fit a boot solenoid and de-lock!
oldeboi - wish I had the time to get a popper installed :) just don't have the money :lol: repairs costing more than I had hoped :p
Just had a think and realised, there was no o-ring when I removed the lock :lol: explains why I had to use a wheel bolt to knock it out the boot since it had jammed in :doubt: stupid previous owner.
EDIT - just been re-reading what you said, the 6n doesn't have a push-button :lol: do you mean between the cylinder and the bootlid?
Edited by NEPolo
