Pedal Boxes
i took me car to a a specialist today and he said me pedal box is going but he doesn't know how long it has left, what sort of things apart from the clutch pedal going down to the floor and never coming back up do i need to look for? and what is the average cost of repair i've been quoted £310+ VAT for when it eventually goes
this includes welding a brand new pedal box before putting it in to ensure it doesn't happen again.
cheer in advance for any advice
  • Replies 9
  • Views 1.4k
Why does the specialst thing your pedal box is on its way out? Generally the weld on the top bracket for the pedal will jus come away, it wont gradually get worse itl just happen.....last time i did one at work it came out around £200 quid the pedal box is only about £35 quid from vw and you need a new plastic clip for the brake servo which is about 2 quid.....Also id make sure they arent just going to weld up your old pedal box.
he said that there was a crack in it and that the pedal has moved.
i had new gearbox and clutch back in november so if it had started to crack in the welds before then would the new gearbox and clutch hold it off for a bit? the clutch isn't hard or anything
doesnt matter when they break you will know you will hear a crack then the car wont go in gear do the job yourself its easy enough just takes paitence look under your dash at the pedals and at the top of the box you will see yourself if it is going to snap i think they may be trying to pull a fast one
my accelerator pedal snapped away from the bulkhead on my mk3 the other day their is no warning they will just snap
you can get the original one welded i think and that only costs about £60.
They generally creak with every press before they go..
Just buy a new one to replace it with from VW.. they are like £35 and shouldn't need re-welding as they will have been fixed.
I had one that had been re-welded at some point in it's life and it became almost impossible to get into gear with the clutch fully adjusted before it finally broke. Had it bolted back together for £50 which lasted a few months before it went again so got it replaced for about £200.
cheers guys there is no creaking or anything so i'll take it as the garage trying to rob me but i'll go somewhere else to get them to check it out too
I've done one of these its easy enough if you have the patience of a saint and a mechanical mind.
As stated parts are cheap its just the labour that mounts up, between £200-£340 is fair if you go to a garage imo.
And i wouldn`t get the new one welded up, or get the old one bolted/welded.
The pedal boxes are desingned in such away that the pedal collapses, in the event of an accident an stops you breaking you ankle.
I had an accident in an old car a while back an crushed my ankle and trust me its better to pay the £200 than fuck your ankle up, the new item is a revised design so shouldn`t break ( there was a recall for these on the 6n/6n2 iirc).
For loads of info on this i`d reccomend having a look over on club lupo.
Peddle box wnet on my 6n2 at 35k. Had major problem getting into all gears and peddle was squeaking. £250 for new one inlcuding labour.
