Up for a challenge, 6N with power - HELP!
Hi all,
I'm a noob but have paid up, just waiting for the nod. Still. I have a Polo 6N 3dr in grey metallic, I would take a pic, but it's dark and she's no looker even in the daytime, still it's a 1.4 CL, no dents anywhere (not even under the rear bumper!) but it's tired (125K) engine wise and TBH an ideal shell with a s**t engine in it. So here begins the challenge.
I would like to put something quick in under the bonnet, my daily is an S3 but want to go NA on this one. Before I go hammer and tongs into this one, if I add the power to the car, will the chassis be up to it? Are these a worthwhile project for a track day car? The car is in good nick in all honesty but with the miles is was very cheap, can't help but think it could be a great VAG project?
Your thoughts would be more than welcome and of course point me at areas of the forum to cover this.
  • Views 984
Sounds like a tidy motor mate, I'm not sure 6n's are the ideal track car but i dont see why not in trying! ;)
If your looking for an gennerally easy (cheap) swap go for the 1.4 16v AFH polo engine pretty much straight swap but you might want to upgrade brakes etc...
Or you could look at the golf/corrado/cordoba engines like a 1.8 16v or a 2.0 16v but these require different engine mounts among other bits and bobs.
Any of them you can work on to gain power e.g. stainless manifolds, cams, carbs, just different set ups....I'm currently in the process of putting carbs and cams in my 1.4 16v.
Looking at figures my 16v standard is a 100BHP but with a BMC CDA induction kit, Stainless 4-2-1 manifold, Stainless 2 3/4" straight through decat and a Chip fitted by Poloace on this forum its running 123BHP and 120ft/sq lbs torque.
Or you could do a N/A 1.8 20v but these require more work...
Theres plenty of threads on engine changes in this part of the forum..... http://www.clubpolo.co.uk/forum/index.php?showforum=4
Hope this helps (Y)
Edited by Mattnaz
Thanks, I'm looking for a little more power than that though, if the chassis will cope. I was hoping for 180+BHP. I am hoping for a VAG lump and wiring loom, ECU etc and the interior of the car bespoke to run this, or a dash from the donor, that sort of thing. All of this is a waste though if the chassis just isn't up to the job.
Whats the quickest 6N out there? Had a quick look on the link you gave me, but nothing, mega pokey there.
if you want that sort of power from an N/A then really you need to be looking at base engines like the 1.8KR 16v lump from the mk2 golf gti 16v. uprate the cams, fit ITB's and some form of management to run them, decent exhaust set up and maybe a bit of head work?
it really depends on your budget and fabricating skills though because fitting these engines isn't easy, it has been done but it would required, custom engine mounts, custom drive shafts, possible chassis leg modifying and the list goes on.
if you have got the skills and know how to do this sort of work or have the cash to pay some one thousands to do it for you then it's all good. if not it might be best to sell the polo on and buy a mk2 golf because every thing that would be a struggle on the polo would be plug and play on a golf. they are designed to run the bigger engines and every thing from the revvy 16v's to the grunty VR6's and even some 1.8 20vt's (although you mentioned boost wasn't what you were looking for) all bolt straight in.
duno but you can pretty much guarantee it will have a 20vt in it :lol:
ashes polos running a 20vt at 331bhp... i know its a turbo and not NA but just shows the chassis can handle it ;)
