mk2 polo reverse light
is the mk2 polo reverse light in with the brake lights or is it seperate as when i reverse my fog light seems to come on for some strange reason? just wondering if i should wire up a seperate reverse light then re-wire the fog light
  • Views 1.2k
its part of the light unit. you might have a LHD rear light unit
Didn't think of that, might just wire up a reverse light then
Are they aftermarket light units? Or are they the same both sides? Does sound like LHD one to me too.
When in reverse,the light on the passenger side should light up. And when the fog light is on,the light on the driver's side should light up. If the positions are correct,and they're just the wrong colour,then you have LHD lenses and they need to be changed for RHD ones.
Ye this is what's happening, I'm just gunna buy a reverse light and stick it on bumper as I like the even look it's got from the back :)
Yeah I've got fogs both sides and no reverse,it looks so much better symmetrical. Its perfectly legal not to have a reverse,too.
Fog lights are a requirement, Reversing lights are not.
And tbh having the LHD unit makes the cars look so much nicer.
In mine I cut the reverse light wire and spliced into the fog line so I have two fogs and if I need light to reverse I just switch those on.
