Front side light and rear sidelight off
I've noticed that my front passenger and rear passenger sidelights do not switch on at all, I'm taking a guess I've pulled a wire or something?
any ideas what it could be? low beam and high beam work fine and the brake light etc work
just the sidelights not working?
  • Views 8.1k
You have blown a fuse mate
Fuse box is at - Driver's side mini cubby hole under headlight switch.
Reach in and pull out plastic panel - fuse card and removing tool on rear of panel.
damn really , I'm such a fool ill check tommorow. grrr
my passenger one has gone also, do you know the fuse position on this? think mine may have blown when putting an LED at the back of the car :S
cheers all
Fuse #4 left side, fuse #5 right side, both 5amp
