Side strip finishing
just removed the side strips form the polo and I'm left with some "glue" residue that wont come off, tried the heat gun, tried the scraping and tried boiling hot water with a hard wearing dishcloth...
so far I'm losing this fight of the glue vs man
grrr
this is what I'm stuck with
cheers
  • Replies 17
  • Views 1.2k
Toffee/Fudge wheel that shit ;), around 7 quid i think from some motorfactors or ebay!
Jake
Thanks for pointing the obvious out for me haha
never really played about with the outsides befor.
S'alright haha!
Samee, I'm debating on killing the surface rust patches on mine soon! And maybe some exterior works, sketchy stuff!
Jake.
beaten to it. Yes use a toffee/fudge wheel
i had the same thing happen and the fudger just seemed to melt the glue and spread it about even more.
it's got to the point where I'm going to take it back to bare metal and build it back up, I can't see a way out.
your solution is go to any car paint suppliers and get 2k paint thinners apply that on a cloth and wipe it straight off after that i would reccomeded getting some panle wipe and just clean the panel off hope it helps mate or if your any were close to burton upon trent bring it to my bodyshop and you can borrow the thinners off me
would mate but I'm in peterborough, its missions away lol.
all i have round here is halfords and we all no exactlly what there like....
hahahaha
caramel wheel it, (called eraser wheels on ebay) and use the side, as its harder, just let it cool down every 20 seconds or so as it will get too hot and spread it. Mine took about 30 mins if that to do both sides. hope this helps :)
sounds silly i know but i have always used wd40 it soffens it up and can rub straight off hope this helps
i used nail varnish remover and white spirit soon come off then :)
I always use tar and glue remover... Then a bit of t-cut to finish it off.
I was probably doing it wrong, but I borrowed some 2k thinners off our bodyshop and it seemed to take the laquer off. It looked like I'd scotchbrited the panel. Any ideas what I was doing wrong?
ah, and that's what I was doing wrong there... thanks for the advice!
By accident i managed to get it all off, used petrol on a rag to get it off, but left it there for a few mins to soak in, leaft it for a min, maybe 2 to go grind something, a spark must have flown past and onto it as it was on fire when I turned around lol.
Good Job I had the fire extinguisher near by lol
did the trick tho
haha thats a good idea set it on fire to get it off.
joking man glad its come off
White Spirit, engine degreaser, or motorcycle degreaser worked fine for me.
Obviously give it a good wash afterwards and then wax.
hey buddy sorry to hear that your paint was affected but 2k thinners are not set to damage the paint in any form or shape all you needed to do was apply the thinners on a clean cloth and just rub it in to the glue it should have come straight off i take of door strips and etc for living and never ever had any problems if you can just email me some pics of the area that you applied the thinners to i can guide you from their what to do then hope it helps.
thanks for the offer, I've cut and filled and generally messed up more of the body since then, so it's not really a problem anymore...
'preciate the help though man
