MK2F Headliner
I know there are FAQ's for headliners, but they're for the mk4 headliners where they come out as a board, and mk3's don't have these, how would i go about retrimming my headliner?
Jake
  • Views 1.3k
it is possible but its time consuming,
Mk4s are piece of piss as its made from a big sheet of recycled bogroll, cardboard boxes and shit like that, so it comes out as a 1 piece stiff item so anyone can do them with very little effort.
mk3s are harder as its a traditional style fabric, rods and glue.
non sunroof cars are tiny bit quicker/easier.
basically you remove:
*all the door and tailgate rubber seals
*the front and rear side glass and rubbers use 2 screw drivers and have a friend hold it so it doent pop and smash on the floor
*the sun visors, passengers grab handle if applicable
*the rear view mirror (30 deg trun and it falls out)
*internal light
*remove the 17mm top seatbelt mounts
on sunroof models open it right up, remove all the screw on the top side and the 2 inside, wind it half closed then pull it up and forward very slowly (watch you sunroof paint on the roof lip) till its totally out and remove the edge trim inside the car.
thenwhen all the above is done slowly lift the weeflaps off material all the way round (hair dryer helps and avoids rips)
then it should be just hanging there.
so u push backwards (to rear of car) the 2 metal rods in the rear and they fall out the wee clips - push it next to the clips or you risk ripping it.
The rear tailgate bit then needs done (hairdryer time) it can be a bitch and will rip somewhere its just minimising the rip, so handy to have a spare bit of material cup out another car to patch it here if needed.
putting the new one in is reverse of the above but you need to use contact adhesive to stick the wee flaps of material down again.
from a donor car you need:
*full headliner
*sunroof panel if applicable
*sunvisors and clips if you changing colour
*sunroof panel edge trim if you changing colour.
could do it easily over a hot sunny weekend, hardest bit is getting the front screen in its tight at the dashboard so put that bit in first. or remove the dash and its much easier but that adds on 20- 30mins worth of work.
Edit note: the above is for a squareback i think coupes have 1 less metal rod (cant remember off hand).
Edited by genesisGT
non sunroof cars are quicker
*internal light
on sunroof models open it right up, remove all the screw wind it half closed then pull it totally out and remove the edge trim inside the car.
then slowly lift the weeflaps of material all the way round (hair dryer helps and avoids wrips)
so u push backwards (to rear of car) the 2 metal rods in the rear and they fall out the wee clips.
putting the new one in is reverse of the above but you need to use contact adhesive to stick the wee flaps of material round.
*full headliner
could do it easily over a weekend, hardest bit is getting the front screen in its tight at the dashboard so put that bit in first.
Edit note: the above is for a squareback i think coupes have 1 less metal rod (cant remember of hand).
Spot on! Thankyou, seems like a right bloody effort though haha ill keep that in mind!
Jake
