number plate lights
hi all
was putting some fancy LED plate lights on and they both went off to a pop sound, have i blown the fuse? if so where is the location of the fuse box in my polo 6n2 x reg?
hope someone can help! thanks in advance
  • Replies 12
  • Views 5.6k
Driver's side mini cubby hole under headlight switch.
Reach in and pull out plastic panel - fuse card and removing tool on rear of panel.
PoloD.
PoloD.
WOW super fast reply! thanks very much, do you know what fuse would be required?hope it is the fuse you dont think i could damage the bulb housings ?
thanks for the help!
Nath
Should be a card on the pull out panel.
PoloD.
Likely installed LEDs wrong way round (they are diodes). Have you tried putting the original W5Ws (W501) back in?
PoloD.
hi all
I'm wanting some white led bulbs for my 97 polo mk4. Number plates. Just woundering were peeps are getting them from ? ? Website etc
Tom
PoloD.
hey mate, tried putting my originals back in and they wouldnt work, hope I've not done any mad damage, they were canbus error free white LED bulbs
Fuse #2 5amp
Fuse #2 5amp
thankyou nige! brilliant diagram will come in hand in the future no doubt, thanks once again mate
nath
Fuse #2 5amp
nath
If you have a look at this http://www.clubpolo.co.uk/forum/index.php?...p;#entry2013075 scroll down to #13 post and there are pics of all the fuse's and relays
Fuse #2 5amp
nath
nige is it the 20mm fuses i need or 10mm?
cheers buddy
From just looking at the picture I'd say 10mm but just pull it out and measure it??
brill mate will do, thanks hope youre well!
