Windsor Blue, non sunroof G40
Up for sale we have my windsor blue (best colour), non sunroof G40. She has been my daily driver for the best part of three years, never skipping a beat and I will be sad to see her go, but its time for a change. Any way the details are:
Engine
109,000 miles
Charger rebuilt 15K ago by Jabbasport
Cone filter
GT inlet
65mm Toothed pulleys (+chip to suit)
4-2-1 manifold
Powerflow exhaust
Samco hoses
Drive
60/40 TA Technix shocks and springs
G-laderseite ARB blocks
Staggered Smoor Roadsters 13x7 front, 13x8 back (with a little stretch 8-) )
Interior/Body
Boost Gauge
Debadged Grille
Trim removed
Not massively modified but enough to give it a bit of poke! The car has been well maintained during my ownership with the following having been replaced (I'm sure theres more but this is all I can think of atm):
Battery tray repaired following rust damage (common problem)
Both fuel pumps
Alternator
Hydraulic tappets
fuel tank (painted and undersealed before fitting)
cambelt/waterpump
lambda sensor
blue temp sensor
rear wheel bearing
rear brake cylinders + shoes
regular oil changes every 3000 miles
Bad Bits:
As you can see from the pictures the bodywork is generally quite shabby. There is lacquer peel on the bonnet and roof and the drivers side has a few areas of rust showing which seem to have sprung up this past winter. I was never in a position to fix the bodywork due to work commitments/other areas of the car to spend money on.
The freezing mornings have caused it to idle rough when cold, this could just be a case of replacing the blue temp sender again (they are notoriously bad). After a few minutes the car is fine.
Extras
The car will come will all parts to return it to standard including:
Inlet manifold
Original pulleys
exterior trim (including badged grille)
Airbox
Manifold + Cat
The car has two sets of wheels and therefore will have two prices listed; one with the winters (14" bbs RA's, see below) and one with the smoors + winters. Please note CD player will be different to the one shown in the pics.
With that in mind I'm asking:
£2300 ono with smoors + winters
£1850 ono winters only
Cash sale only, i'm not interested in a p/x thanks.
The car is based in Malmesbury, wiltshire.
Contact me via PM or on 07825669797 after 5:30.
I have tried to be as honest as possible, thanks for looking,
Danny
*edit forgot to mention battery tray*
Edited by Guest
  • Views 470
also forgot to add, 3 months MOT and I will update later about tax.
danny
tax until 31st july.
