roof chop breaddy
  • Replies 12
  • Views 1.3k
crazy!! got me thinking now though, as its not too far from me :ninja:
someone please buy this and make it good!
it was originally done by a local legend, would be ace to see it properly tidied up.
Saw this the other day on a local forum, looks proper horrible at the moment. What it needs is RWD, loads of rake and massive rear tyres and it would be cool as fook.
Wondered when this'd get posted up!
THE POLO HAS BEEN USED ON THE ROAD SINCE ITS TRANSFORMATION SO GETTING IT MOTED WONT BE A PROBLEM.
Yes it will :lol:
How will it not be a problem getting an mot on a pick up when on the computer system it will come up as a hatch back? As soon as it goes in for an mot and it says its a pick up it will be flagged up on the dvla system. They will then contact the owner asking what's occurring, once you tell them its been turned in to a pick up they will take log book off you and tell you it needs to go for a IVA test and this is where the fun begins because there is no test for a modified monocque (sp) pick up, but the dvla won't give you your log book back till it passes a test, so your screwed.
Pisses me off when you get people misleading potential buyers like that, if they had done even the slightest bit of home work on it they would know that the only possible way to drive this on the road legally is to mount the shell in to a separate chassis (like they do with minis and SJ chassis).
some one could buy this going off his misleading description and find himself in a nightmare of dvla red tape :disgust:
It'd be interesting to see what the people that drive these sort of cars on the road have them insured as, surely if you told them it had been made into a pick up they would ask to see proof that it had passed the appropriate tests to prove that its road worthy? Which it is impossible to get because there isn't currently a test for this class of car
Edited by McLOVIN
polo on an sj chassis sounds fun about now ha ha
I like that.
As for running it on the road. I guess its like every other radically altered vehicle running around, just get a test on it at a known good MOT station, and insure it as a custom car. Then just hope you dont crash into an orphanage.
You could IVA test it if you wanted but it would be a nightmare.
You can't IVA it thats the problem. Most cars post 70s are dead easy to IVA as they were already type approved so as long as you don't do anything daft like fit a chain link steering wheel or whatever. The problem is that currently there isn't a class to IVA cars cut down into pickups.
Matt
I always thought the saloon would make a better pick up. Just looks too short at the back
And what does the roof look like it's in two halves :?
I'd only looked at the first pic before and just had a look through the rest of them, that looks like a right fucking death trap :lol:
Prankster the roof would of needed to be cut in half and a bit welded in to make it wide enough to fit, the roof pillars go in towards the top so if you try and fit the roof further down them it won't be wide enough.
surely the requirement of an IVA test depends on when it was converted and if the v5 was updated at the time of the conversion. Its only in the last couple of years that the rules have got strict. There was a breadie pick-up built by a guy on here, 3 or 4 years ago (ollythedolly) i think was his username and I'm fair sure that didnt get IVA'd
think it's some thing like 10 years jon, if it was converted before then and the log book changed to suit then it shouldn't need a iva test iirc. it's not that they've recently made the rules strict, the've just started enforcing the existing rules.
you could get it tested and put on the road legally, but it would cost around 10k, and thanks to the seller the people that are bidding on it probably think it's only going to cost the price of an mot :?
there's more info of it in this thread click me.
it's one of many posted up on retro rides on this subject, i'll quote the relevant bit here tho for the lazy among us :lol:
It's a no-go on putting it through BIVA I'm afraid . Bear with me on this one, BIVA is for M1 cars and has a section for modified production cars. making it into a pick up means it is classed as a N1 Goods Vehicle and woudl have to go for the old SVA test. However as it's not a 'groundup' build it means it is a modified production car and under SVA there is no method of testing other than ESVA .
SVA is a VERY high spec and the additional proofs and tests involved would cost £8-10,000!
but the thread is still worth a read if you are thinking about chopping the back off any thing any time soon.
