Bumper trim damaged
I tried to pull up at the side of a country road the other day, not noticing the sheer amount of grit on the road, and ran the car into a large tuft of apparently very hard grass. The only damage was that the black strip of plastic that runs along the front of our MK3 Polo has basically unclipped itself. I can feel that there's a hole in the plastic, and that there's a piece of something that it would seem it should clip on to - but I can't seem to get it to locate. Is it possible that I've just widened the locating hole or something? If so, how much is a replacement plastic likely to cost, and how easy are they to fit?
Cheers in advance.
Matt.
Edit - See the attached file if you're confused about what I'm actually talking about.
Edited by bluemac
  • Views 767
Its called a splitter
That bit is normally called the front splitter or front valance :)
Shouldn't be too much to get, may be able to get them from a local scrappy.
If I remember correctly, it doesn't clip on, it has screws that go through it into a plastic clip which the screw screws into (if that makes sense). If you check the rest of it, you should notice what I mean.
