Early Mk3 Polo Heater Matrix Pipe Needed ASAP!
Hey
I'm after the hose from and early mk3 polo that runs between the heater matrix and the water pump rail ont he back of the block...
Thanks,
Ad
  • Views 506
might have one here, is there a difference on later mk3's?
hey man - yeah it may be between SPI's and other engines rather than late to early... basically the late spi engine I had in before the early G40 engine has a wider bore on the pipe running in to the water pump rail...
the early G40 one is roughly the same size as the other tube on the thermo housing that runs to the heater matrix... I think I have one that I can borrow off ma mate but will need to hook him up with a replacement!
Drop us a text or something if you find one... cheers man
Ad
Etka lists a 20mm and a 25mm return pipe depending on chassis number. Would have thought i'll have one but will check tomorrow after work.
got both versions here,just checked ;)
