Lacqure problems Any tips?
I have had this car a year and a half, the lacqure on the front bumper and bonnet seems to just have bassically come away. No other way of describing it.
Any help?
Is this a respray job?
Edited by hally11092
  • Replies 8
  • Views 940
yeh needs sanding right back and repainting
Is it that bad?
yep
How much you think it will cost and would the whole of the bonnet need doing?
looks too me like when the basecoat has been applied it was left too long to dry and when the lacquer had been applied its not taken to the paint and not just pealing away
full bonnet and bumper would need redone, to be safe i'd strip the bumper hack to plastic and the bonnet back to original factory primer if not bare metal
£3-400 at a guess
price depends on the bodyshop, no one can predict what your local place will charge.
i wouldn't strip the whole bumper back to plastic, or even the whole bonnet back to paint. just D/A or sand down the effected areas then scotch the rest. but to be honest, i wouldn't suggerst you do anything you haven't done before. a bodyshops worst nightmare is when a complete amateur does thier own prep' work and fucks it up, it normally just creates more work than nessecary.
id want both panels stripped back to at least the original primer
whatver has caused that to peel will have been done all over the panels , so taking it all off will eliminate the chance of more coming off
